How to Drive 5V DC Motor Using PT2272 RF M4 Receiver 315MHz Output Pins?
339 8
  • Receiver output cannot drive motor directly
    #1 21671346
    Ramien Ebadypour
  • Use an N-channel MOSFET as a motor switch
    #2 21671347
    Joshua Bishop
  • #3 21671348
    Ramien Ebadypour
  • #4 21671349
    Ramien Ebadypour
  • #5 21671350
    Ramien Ebadypour
  • Recommend a power MOSFET with flyback diodes
    #6 21671351
    Joshua Bishop
  • Separate motor supply breaks receiver wiring
    #7 21671352
    Ramien Ebadypour
  • Shared ground needed between receiver and motor supply
    #8 21671353
    Joshua Bishop
  • #9 21671354
    Ramien Ebadypour
A user seeks to drive a 5V DC motor using a PT2272-based RF M4 Receiver operating at 315 MHz, connected to one of the receiver's data output pins. The receiver outputs 5V logic signals but cannot directly power the motor due to limited current sourcing capability (~20mA), while the motor requires significantly higher current. The recommended solution involves using an N-channel MOSFET as a low-side switch: the motor connects to 5V, the MOSFET drain to the motor, source to ground, and the gate driven by the receiver output. This configuration allows the MOSFET to switch the motor current safely. No inline resistor is necessary on the gate, but a flyback diode (rectifier) across the motor terminals is advised to protect the circuit from voltage spikes caused by motor inductance. When using separate power supplies for the receiver and motor, a common ground reference is essential to ensure proper operation and avoid floating voltage levels. Additionally, a Zener diode may be used for further protection. The discussion includes schematic verification and component selection advice, emphasizing MOSFETs capable of handling at least 4-5A with gate voltages compatible with 5V logic.
