Running and Dimming 10-15A LEDs With PWM, SMPS, PIC, MOSFET—Drawbacks or Issues?
354 6
  • Potential drawbacks of PWM LED dimming with SMPS and MOSFET
    #1 21684522
    Graham Rounce
  • Use dc/dc converter and shielding for PWM LED drive
    #2 21684523
    Giovanni Di Maria
  • #3 21684524
    Graham Rounce
  • Choose PWM frequency to avoid interference
    #4 21684525
    Giovanni Di Maria
  • #5 21684526
    Graham Rounce
  • LC pi filter recommended for PWM harmonics
    #6 21684527
    Giovanni Di Maria
  • #7 21684528
    Graham Rounce
The discussion addresses the design considerations for running and dimming high-current LED loads (10-15A) using PWM controlled by a PIC microcontroller, powered by a switch-mode power supply (SMPS), and switched via a MOSFET. Key challenges include managing high current and mitigating electromagnetic interference (EMI) generated by PWM switching. It is recommended to power the PIC separately using a DC/DC converter to isolate control circuitry from noise. Using SiC MOSFETs with low RDS(on) is advised for efficient switching and reduced heat dissipation. EMI concerns can be addressed by selecting an appropriate PWM frequency (typically between 20 kHz and 400 kHz) to avoid interference with AM radio, TV, and WiFi bands, and by implementing LC low-pass filters (Pi or T configurations) to attenuate high-frequency harmonics. Proper shielding, filtering capacitors, and good grounding practices further reduce interference risks. Testing interference with an AM radio is suggested to evaluate EMI presence. Overall, with careful design, PWM dimming of high-current LEDs using a PIC, SMPS, and MOSFET is feasible without significant interference issues.
