Where to Buy Solder Cups for ESCs That Fit 10 Gauge Wire for RC Car Racing?
258 9
Where can I buy solder cup terminals for an ESC that will accept 10-gauge wire for RC car racing?
Contact sales reps at major electronics distributors such as Digi-Key, Mouser, Newark, Allied Electronics, Future Electronics, or Avnet, because they may be able to locate the exact part and manufacturer for you [#21671726] [#21671730] [#21671733] The cup is soldered to the circuit board, so you are looking for a solder-terminal style connector rather than a separate in-between part [#21671729] It was also noted that the top end looks like a standard electrical solder terminal, similar to the solder cup used in 4 mm meter test plugs [#21671728] If the original part cannot be found, a pair of those test-plug solder cups might be cut down to fit [#21671728]
  • #1 21671724
    Irish Racing
  • #2 21671725
    Frank Bushnell
  • #3 21671726
    Steve Lawson
  • #4 21671727
    Steve Lawson
  • Solder cup terminal may be cut down from 4mm plugs
    #5 21671728
    Frank Bushnell
  • #6 21671729
    Irish Racing
  • #7 21671730
    Steve Lawson
  • #8 21671731
    Michael Levin
  • #9 21671732
    Irish Racing
  • Clarifying source versus manufacturer for parts sourcing
    #10 21671733
    Steve Lawson
The discussion centers on sourcing solder cups compatible with Electronic Speed Controllers (ESCs) for RC car racing that can accommodate 10 gauge wire. The solder cups are typically soldered directly onto the ESC circuit board. While standard electrical solder terminals and 4mm meter test plug solder cups resemble the required component, exact matches are not readily found through common distributors. Suggested distributors for sourcing these components include Digi-Key, Mouser, Newark, Allied Electronics, Future Electronics, and Avnet Electronics. Engaging sales representatives at these distributors may help locate suitable parts or manufacturers. The original poster seeks production quantities (500+ units), emphasizing the need for a reliable source rather than just a manufacturer. Hobby shops may carry connectors for ESCs, but they are unlikely to meet large-scale production needs.
