How to Detect and Measure Low Frequency Microwave Modulation?
291 7
  • #1 21673619
    Vishnu T
  • #2 21673620
    richard gabric
  • #3 21673621
    Orin Laney
  • #4 21673622
    Vishnu T
  • #5 21673623
    Vishnu T
  • Broadband field strength meter recommended
    #6 21673624
    Orin Laney
  • #7 21673625
    Vishnu T
  • Microcontroller control-loop harmonics as likely source
    #8 21673626
    Orin Laney
The discussion addresses methods to detect and measure low frequency modulation on microwave signals, specifically in the 0 to 100 Hz range. Detection typically involves using microwave detector diodes rather than PIN diodes, which are suitable for modulation generation but not measurement. Integrated circuits from manufacturers such as Analog Devices, Maxim, and Linear Technology can demodulate low frequency modulation from microwave carriers. The LTC5564H is cited as an example IC for this purpose. For practical measurement, field strength meters from companies like Narda Microwave or low-cost broadband designs found in ham radio resources are recommended. A simple homemade detector can be constructed using a microwave Schottky diode, a single-turn loop antenna, and an RC filter feeding a headphone amplifier to qualitatively listen to modulation, though a meter is needed for DC component measurement. Visualization of microwave fields and portable detection devices were also queried, but no specific solutions were provided. Additionally, a sound file related to the modulation was discussed, with speculation that it might represent microcontroller switching harmonics rather than direct microwave modulation.
