Wiring Arduino Digital Output to PIC 12F683 GPIO with Separate Power Supplies
315 6
  • Need for level shifting between separate supplies
    #1 21673838
    Bob Pombrio
  • Opto-isolator recommended for isolated Arduino-to-PIC signaling
    #2 21673839
    Dean Franks
  • #3 21673840
    Bob Pombrio
  • #4 21673841
    Dean Franks
  • #5 21673842
    Bob Pombrio
  • Optoisolator interface for isolated Arduino to PIC signals
    #6 21673843
    Dean Franks
  • #7 21673844
    Bob Pombrio
The discussion addresses interfacing an Arduino digital output with a PIC 12F683 GPIO input when powered by separate power supplies. The main concern is ensuring a common reference ground or using isolation to prevent noise and potential differences from causing signal errors. Direct wiring requires a shared ground to establish a potential difference; otherwise, the signal line will carry noise. A recommended solution is employing an opto-isolator (opto-coupler) on the PIC side to electrically isolate the Arduino signals, allowing multiple PICs to receive signals without ground conflicts. For typical low-frequency signals (
