Converting 3 Phase PWM Output from Solar Inverter to Single Phase Pure Sinewave
336 7
  • #1 21673850
    Subash Pandey
  • Sinusoidal PWM and LC filtering needed
    #2 21673851
    Sree Harsha Angara
  • Duty-cycle variation limits sinewave conversion
    #3 21673852
    Rohit Dubla
  • PWM duty cycle must stay fixed at zero mean
    #4 21673853
    Sree Harsha Angara
  • #5 21673854
    Justin Spencer Mamaradlo
  • LC filtering needed for high-power inverter output
    #6 21673855
    Sree Harsha Angara
  • #7 21673856
  • LC filters allow higher current with lower loss
    #8 21673857
    Sree Harsha Angara
A solar-powered three-phase inverter outputs PWM signals that can directly drive three-phase motors but are unsuitable for control panels requiring single-phase pure sine wave power. Converting the inverter's PWM output to a single-phase pure sine wave involves sinusoidal modulation of the PWM at high frequencies (typically 100 kHz or higher) followed by filtering. The recommended filtering method for power-level applications is an L-C low-pass filter, which is more efficient and less lossy than simple R-C filters, as inductors handle higher currents with lower power dissipation. The inverter's PWM is generally a 50% duty cycle square wave at 50/60 Hz, with power regulation handled upstream by a DC-DC converter stage adjusting voltage based on solar irradiance. Directly filtering a low-frequency PWM square wave is impractical due to numerous harmonics; instead, high-frequency PWM modulation combined with L-C filtering yields a near-pure sine wave output suitable for sensitive single-phase control equipment. Key references include power electronics literature such as "Fundamentals of Power Electronics" by Erickson.
