Seeking Pure Sine Wave Inverter for Direct Use with Photovoltaic Panels
specek 12225 9
Can I use a pure sine wave inverter directly from photovoltaic panels without batteries, and what kind of device would work for that?
A pure sine inverter powered directly from PV panels is only practical in a limited way, because without batteries there is no buffer and even one cloud can knock the output down. [#18382327] Devices like the SinusPro S are mentioned as working from panels, but only until the first cloud or until the load exceeds the panel output. [#18383068] For a resistive load such as a heater, a modified/rectangular sine version is considered sufficient, while the thread suggests that a true sine version costs over a thousand PLN. [#18382327][#18458080] One reply also breaks the price range down as about 500 PLN for a regulator with DC output, about 800 PLN for a rectangular-sine unit, and over 1000 PLN for true sine. [#18458080]
  • #1 18379402
    specek
    Help: 20
    Rate: 123
    Hello cordially
    I am looking for an inverter that works directly from photovoltaic panels and has a pure sine wave of AC current at the output. There is such a thing?
    I only found an inverter with a modified sine wave at the output.
  • #2 18382327
    ACCel
    Help: 24
    Rate: 217
    How would this inverter provide stable power at the output of the system without a buffer in the form of batteries? One cloud and you're done.
    You can at most connect this to a heater, which is indifferent to the stability of the power supply.
  • #3 18383068
    MichałS
    Level 36  
    Help: 256
    Rate: 683
    SinusPro version S, but as they write; it will work until the first cloud, or until the power consumed exceeds the yield of the panels.
  • #4 18383235
    specek
    Help: 20
    Rate: 123
    I realize that until the "first cloud" it will work. I need something in the range of 150-280V at the input. If I give 7 panels x 39.1V = ~278V. I will try to regulate the fluctuations with an automatic AVR Power consumption is max 200W (emergency situations). Only SinusPro S is suitable for this?
    I'll tell you this: the inverter must have a sine wave because it can be used in emergency situations to maintain voltage, for example, a refrigerator (I know that only during the day and in sufficient weather), on a daily basis will be connected to a 1.5kW heater and therefore there can be no battery.
  • #6 18453837
    baru0
    Rate: 16
    This is not a cheap subject ,closes in the amount of more than a thousand
    Mr. Wojtek has a wide range of devices .
    I am still looking for "luck" on the Internet ;) .
    There is also something like this from these "rectangular sine wave"
    Link .
  • #7 18456690
    anaba255
    Help: 95
    Rate: 262
    baru0 wrote:
    This is not a cheap subject,closes in the amount of more than a thousand.
  • #8 18458080
    baru0
    Rate: 16
    500PLN regulator with DC output .
    800PLN rectangular sine .
    True sine over a thousand, that's why I'm pinching myself a little .
    Contact very good , but I will still look .
  • #9 20428615
    benonlakowski
    Please contact the "Faucet World" store where you will get detailed information on this subject!
  • #10 20428714
    TIGIS
    Help: 10
    Rate: 20
    What a dig ;) .
The discussion revolves around the search for a pure sine wave inverter that can operate directly from photovoltaic panels without the need for batteries. The user expresses a need for an inverter that can handle input voltages between 150-280V, specifically mentioning a configuration of seven panels producing approximately 278V. Responses highlight concerns about the stability of power output during variable weather conditions, suggesting that such inverters may only be suitable for specific applications like heating. The SinusPro S model is mentioned as a potential option, but users note that it may not perform reliably under all conditions. Other suggestions include various devices available online, with price points exceeding a thousand PLN for true sine wave inverters.
