Recover Photos from SD Card Showing Disk Not Formatted Error Without Formatting
618 16
How can I recover photos from an SD card that shows a “disk is not formatted” error without formatting it?
Yes—do not format the card, stop using it, and try to recover the photos with memory card recovery software from a card reader before anything new is written to it [#21673982] [#21673984] [#21673985] One reply says this error often means the card file system has become RAW, and that formatting would only convert it to FAT32 or NTFS after erasing the chance to recover the photos [#21673986] Another suggests keeping the card out of the camera and using a different card reader to run the recovery tool [#21673990] If the photos are recovered, save them to another drive or location right away as a backup [#21673982] One user also reported that leaving the card in the camera and transferring images over USB worked for them [#21673994]
  • Asking how to recover photos without formatting
    #1 21673980
    Igna tivssi0
  • Avoid formatting and use recovery software
    #2 21673981
    Kevin Angelo Ma
  • Stop using and do not format the SD card
    #3 21673982
    Tina Mony0
  • Recommend photo recovery before formatting SD card
    #4 21673983
    Corny heo0
  • Recover photos without formatting the SD card
    #5 21673984
    Amay aser0
  • Formatting error does not erase photos
    #6 21673985
    Gabrielle hu0
  • RAW file system requires photo recovery first
    #7 21673986
    Vilma Baker
  • Recommend SD card recovery software instead of formatting
    #8 21673987
    stephanic taylor
  • RAW file system requires recovery before formatting
    #9 21673988
    Vilma Baker
  • #10 21673989
    chan leen
  • Photo recovery software recommendation for unformatted SD cards
    #11 21673990
    Blair Chen
  • #12 21673991
    allend uncans
  • Recommend using Card Data Recovery software
    #13 21673992
    Lorein Watson
  • Recommend using third-party recovery software
    #14 21673993
    Blair Chen
  • #15 21673994
    Ruben Proost
  • #16 21673995
    Anny Granger
  • Recommends Rescue Digital Media for SD photo recovery
    #17 21673996
    Silvesta Disuza
When an SD card shows a "disk not formatted" error, it typically indicates the file system has become RAW or corrupted, making the data inaccessible without formatting. Formatting the card will erase all stored photos and files, so it is crucial to avoid formatting before attempting recovery. The recommended approach is to immediately stop using the SD card to prevent data overwriting. Users should connect the card to a computer via a card reader and employ specialized photo or memory card recovery software to retrieve lost or inaccessible images. Various third-party recovery tools are suggested, including EaseUS Photo Recovery, Jihosoft Photo Recovery, Tenorshare Card Data Recovery, Rescue Digital Media, and other freeware or commercial utilities. These tools scan the RAW or corrupted file system to recover photos without formatting. After successful recovery and backup of data to a separate storage device, the SD card can be safely formatted to restore normal operation. Additional precautions include maintaining regular backups and avoiding virus infections or faulty operations that may damage the card's partition or file system.
TL;DR: Use a 3‑step process: stop using the card, scan it with photo‑recovery software, and save results elsewhere. "Don't format it yet." [Elektroda, Kevin Angelo Ma, post #21673981]
Why it matters: This FAQ helps photographers fix the "SD card not formatted" error and recover images without risky formatting.
How do I fix “The disk is not formatted” on my SD card without formatting?
Stop using the card. Connect it via a card reader. Run photo‑recovery software to copy photos to another drive. Only format after recovery to restore normal use. As one user put it: "don’t format it yet." This preserves data that’s still present but inaccessible. [Elektroda, Kevin Angelo Ma, post #21673981]
Why did my SD card suddenly show RAW and ask to format?
The card’s file system became RAW, so your OS can’t read it. Cameras and PCs then prompt to format to rebuild a readable file system like FAT32 or NTFS. Recover photos first, then format to fix structure. [Elektroda, Vilma Baker, post #21673986]
What’s the safest first step to avoid losing photos?
Power down the device and remove the SD card. Do not save new files or take more photos. New writes can overwrite the old photo data and reduce recovery chances. [Elektroda, Tina Mony0, post #21673982]
Can I still recover photos if I haven’t formatted the card?
Yes. The photos usually remain on the card until overwritten. Use photo‑recovery software to scan and copy them out. Avoid any new writes to keep recovery success high. [Elektroda, Gabrielle hu0, post #21673985]
What’s a quick 3‑step method to recover photos?
  1. Stop using the SD card immediately.
  2. Connect it via a card reader and run a photo‑recovery tool.
  3. Save recovered photos to a different drive, not the SD card. This minimizes overwrite risk and keeps results intact. [Elektroda, Tina Mony0, post #21673982]
Which recovery tools did users in the thread recommend?
Users mentioned EaseUS Photo Recovery (free option) and Jihosoft Photo Recovery for deeper scans. Download the correct Windows or Mac version and scan the card through a reader. "Be sure you download right Win or Mac version." [Elektroda, Blair Chen, post #21673990]
Will formatting fix the error after I rescue my pictures?
Yes. After you copy out important photos, format the card to rebuild FAT32/NTFS and clear the RAW condition. This restores normal access in the camera and computer. [Elektroda, Vilma Baker, post #21673986]
Can I recover photos if I already clicked the format button?
Focus on cases before formatting for the best outcome. The thread guidance is to recover first, then format. If you haven’t formatted yet, your chances are stronger. [Elektroda, Kevin Angelo Ma, post #21673981]
Where should I save recovered files?
Always save recovered photos to a different physical drive or storage device. Do not write the recovered data back to the problem SD card. This prevents data overwrite and preserves results. [Elektroda, Tina Mony0, post #21673982]
What reduces my chances of successful recovery?
Taking new photos, copying files to the card, or running repairs that write to the card can overwrite the old photo data. Once overwritten, those images are unrecoverable. [Elektroda, Corny heo0, post #21673983]
Could a camera-to-computer USB cable help if the reader fails?
Yes. Leave the card in the camera and try transferring over the camera’s USB connection. Some cameras can still read files even when a computer can’t mount the card. [Elektroda, Ruben Proost, post #21673994]
What causes the error—virus or user mistakes?
Possible causes include malware, unsafe removal, or partition damage. Regardless, avoid formatting, then use a recovery tool to extract your photos step by step. [Elektroda, Blair Chen, post #21673993]
I’m on a Mac. Any difference in steps?
Steps are the same. Use a Mac‑compatible recovery tool, scan the SD card via a reader, and save results to your Mac’s drive. Then format the card. [Elektroda, Vilma Baker, post #21673986]
What is photo‑recovery software?
It scans storage for lost file entries and reconstructs photos without using the damaged file system. You select found images and save them to another drive. ["Photo recovery" – Wikipedia]
