Micro SD card - it can not be formatted in either the phone or the computer
PchlaW81 8316 3
  • #1 16387774
    PchlaW81
    Help: 191
    Rate: 481
    I hooked the cable to the phone and played and uploaded photos to her on the phone - computer line. After this event (which I was a little aware of) is the situation that I removed photos from the position of the computer, on the phone they are, only a black field will be left, yesterday I took pictures and there were no photos of them - the card seemed crazy. It can not be formatted on the phone, on the computer by inserting it into the USB adapter also not from the "New volume" position. Nothing will be from it?
  • #3 16388517
    PchlaW81
    Help: 191
    Rate: 481
    Thanks for the response.
    HD tune shows something like that, another test can not be done:
    However, this program you can not handle - it pops up, you have to unlock the card, and this card does not have this slider on the side to block.
    I would like to add that when switching the phone on and inserting the card into the USB adapter pops up the message to scan the card because it has errors. Scan does not give anything - i.e. repair is not scanning
