How to Build a Contactless AC Power Meter for 3-Core Cables with Arduino Integration
312 8
  • Need for non-invasive AC voltage and current sensing
    #1 21674025
    Damien Dunphy
  • PCB planar capacitive and inductive sensing heads
    #2 21674026
    richard gabric
  • #3 21674027
    Damien Dunphy
  • #4 21674028
    laura white
  • Need separate live conductor for current measurement
    #5 21674029
    richard gabric
  • #6 21674030
    Chris Hill
  • Three-phase measurement complexity and cable access question
    #7 21674031
    richard gabric
  • #8 21674032
    Damien Dunphy
  • #9 21674033
    richard gabric
The discussion addresses building a contactless AC power meter capable of measuring voltage and current in 3-core power cables without separating the live wire, integrated with Arduino for real-time monitoring. Capacitive coupling is suggested for voltage measurement, while inductive methods are used for current sensing. A proprietary three-phase system employing PCB planar sensing heads with op-amps for impedance conversion and ADC voltage output was referenced, highlighting the complexity of measuring currents in cables containing both live and neutral conductors. It is noted that in single-phase cables with tightly coupled live and neutral cores, magnetic flux sensing for current measurement is ineffective because the return current cancels the outgoing current’s magnetic field. The challenge arises from the inability to isolate the live conductor in bundled cables, making conventional clamp meters unsuitable. Alternative approaches include inserting measurement devices between source and load or using plug-in power meters. The discussion emphasizes safety concerns when working with high voltage and the mathematical complexity involved in separating phase signals in multi-core cables.
