I am using Op-Amp OP07 to implement an integrator as part of a dual slope capacitance digital converter circuit. My problem is that the feedback capacitor is slowly charging to saturation. The input resistance is a switched capacitance type. I have not used any compensation in this. Checked with various values of capacitances. The result is same except that the charging time is different. Can you suggest a solution?
SUDHIR KUMAR SRIDHARAN
