LM301A Op-Amp: Why Does 20logA Increase at Unity Gain With 10pF Compensation?
288 10
Why does my LM301A amplifier’s measured 20logA increase at unity gain when I use a 10 pF compensation capacitor in parallel with Rf, while 20 pF and 30 pF capacitors make the gain decrease?
The most likely cause is peaking from oscilloscope probe capacitive loading interacting with the op-amp compensation, not the capacitor value by itself [#21669888] An op-amp’s frequency response can peak with a capacitive load, and the probe capacitance can interact with the 10 pF feedback capacitor differently than with 20 pF or 30 pF [#21669888] To test this, insert about a 100 ohm resistor between the op-amp output and the oscilloscope probe and repeat the measurement; this should help isolate the op-amp from the probe capacitance [#21669888]
  • #1 21669880
    DAVID CUTHBERT
  • Unity-gain compensation capacitor increases high-frequency gain
    #2 21669879
    Hatef Abdollahi
  • #3 21669881
    Hatef Abdollahi
  • #4 21669882
    Hatef Abdollahi
  • #5 21669883
    DAVID CUTHBERT
  • #6 21669884
    Hatef Abdollahi
  • #7 21669885
    Hatef Abdollahi
  • #8 21669886
    DAVID CUTHBERT
  • #9 21669887
    Hatef Abdollahi
  • #10 21669888
    DAVID CUTHBERT
  • #11 21669889
    Hatef Abdollahi
The discussion addresses an observed anomaly in the frequency response of an LM301A operational amplifier compensated with different capacitor values (10pF, 20pF, 30pF) placed in parallel with the feedback resistor (Rf). While 20pF and 30pF capacitors show a decrease in 20logA at unity gain, the 10pF capacitor causes an unexpected increase in 20logA over log(ω) at unity gain, opposite to the other cases. Measurements were taken at multiple frequency points to analyze the compensation effects. The output voltage behavior differs notably with the 10pF capacitor, showing an increase rather than a decrease at unity gain. The measurements were confirmed to be experimental rather than simulated. A suggested explanation involves the capacitive loading effect of the oscilloscope probe, which can cause peaking in the op-amp frequency response due to interaction with the compensation capacitor. To mitigate this, it was recommended to insert a 100-ohm resistor between the op-amp output and the oscilloscope probe to isolate the probe capacitance and obtain more accurate frequency response measurements.
