Eaton Moeller Z-SCH230/25-40 Contactor Coil Voltage: Can I Use 24V DC to Test?
390 6
  • 24 V DC cannot drive this AC coil
    #1 21675216
    ADENIJI SEGUN
  • #2 21675217
    richard gabric
  • Rewiring contactor coil through 24V relay to neutral
    #3 21675218
    ADENIJI SEGUN
  • #4 21675219
    richard gabric
  • #5 21675220
    ADENIJI SEGUN
  • #6 21675221
    Zachary Pick
  • #7 21675222
    richard gabric
A user inquired about testing an Eaton Moeller Z-SCH230/25-40 4-pole contactor by applying 24V DC to its coil terminals (A1 and A2) while connecting a 3-phase AC load to the main terminals. The contactor did not actuate, prompting the question of whether a DC voltage source can drive the coil. Responses clarified that the coil is specified for 230V AC operation, and applying 24V DC directly will not energize it. A recommended solution is to use a low-voltage DC supply to control a separate auxiliary relay, which in turn switches the AC coil voltage of the contactor. Alternatively, replacing the contactor with a model having a 24V DC coil is possible but may be more costly than using an intermediate relay. The wiring approach involves connecting the contactor coil to the AC mains and controlling it via the relay energized by the 24V DC source.
