T8 LED Tube Retrofit: Pros and Cons of Single-Ended vs Double-Ended Wiring Methods
1695 6
  • Questioning why ballastless LED tubes are single-ended
    #1 21675518
    Zachary Barrett
  • Dual-ended T8 tubes cost more due to added circuitry
    #2 21675519
    Thomas Brown
  • Double-ended retrofit tubes with internal ballast
    #3 21675520
    Michele Cecchettini
  • #5 21675522
    Zachary Barrett
  • Double-ended LED tubes now UL approved
    #6 21675523
    Tony Taylor
  • #7 21675524
    Sagar Tanksali
The discussion addresses the pros and cons of single-ended versus double-ended wiring methods for retrofitting 32W T8 fluorescent lamps with approximately 17W LED tubes. Single-ended LED tubes can operate by reusing existing electronic ballasts, using an external driver, or with no ballast at all, simplifying installation but potentially requiring ballast maintenance. Double-ended LED tubes, which power each end separately, are considered inherently safer and easier to retrofit due to simpler wiring and compliance with safety standards. Historically, double-ended designs faced challenges in UL and FCC certification due to leakage current issues, but recent advances in integrated circuits have reduced leakage below 5mA, enabling UL approval for double-ended direct wire tubes. Manufacturers highlight that double-ended tubes are preferred in specialized markets such as marine applications and are gaining traction in the US market with UL and DLC certifications. Brands like Hyperikon offer both single-ended and double-ended T8 LED tubes, with double-ended models typically costing slightly more due to additional engineering and components. New product lines feature various lengths (60 to 150 cm), multiple color temperatures (2700K to 6500K), and high luminous efficacy (up to 150 lm/W) using advanced LED chips such as Nichia 3030. The choice between single-ended and double-ended wiring depends on safety, ease of installation, regulatory compliance, and long-term maintenance considerations.
