Calculating Max DC Bus Voltage from PMSM Line-to-Line Voltage Using 6-FET Inverter
435 4
  • Six-step inverter can exceed diode bridge voltage
    #1 21676053
    A B
  • Boost converter output depends on PWM duty cycle and divider values
    #2 21676054
    Dean Franks
  • Boost ratios above 3:1 increase switch current and filtering needs
    #3 21676055
    Dean Franks
  • Questioning 100% PWM bus voltage and VLL conversion
    #4 21676056
    A B
  • Three-phase rectifier bus equals input peak voltage
    #5 21676057
    Dean Franks
