Schematic suggestions for DIY Computer PSU Tester with selectable load and meters
354 7
  • #1 21676940
    Mike Jobe
  • Active current-sinking load for PSU testing
    #2 21676941
    richard gabric
  • #3 21676942
    Mike Jobe
  • Programmable current sink for PSU load testing
    #4 21676943
    richard gabric
  • #5 21676944
    Mike Jobe
  • Active load design requires op-amp theory and power compliance
    #6 21676945
    richard gabric
  • Need for a switched 800 W PSU load tester
    #7 21676946
    Mike Jobe
  • Electronic load preferred over many fixed resistors
    #8 21676947
    richard gabric
The discussion focuses on designing a DIY computer PSU tester capable of handling power supplies from 100 to 850 watts with selectable loads and voltage and current meters on each output leg. Key challenges include providing appropriate load currents for multiple voltage rails (e.g., ±12V, 5V, 3.3V) and testing outputs simultaneously to verify PSU performance under load. Fixed resistor loads are impractical due to the wide range of current ratings and the large number of resistors and heavy-duty switches required, especially for high current rails like 12V used by modern graphics cards. An active programmable current sink or electronic load is recommended as a more manageable and flexible solution, allowing adjustable load currents and dynamic testing without the need for numerous fixed resistors. The design requires knowledge of analog circuit design, including op-amps and transistor or MOSFET pass elements, with attention to power dissipation, voltage compliance, and thermal management. Analog meters for voltage and current readouts and a multi-position load switch bank are suggested for user control. The overall goal is a reliable, simple, and cost-effective tester that provides more conclusive testing than basic go/no-go LED testers.
