Pulsed DC Supply for magnetizing and demagnetizing of electromagnet
279 7
  • Need for a MOSFET driver to prevent burnout
    #1 21677078
    Priya dharshini
  • Questions MOSFET ratings, flyback clamp, and 555 drive
    #2 21677079
    richard gabric
  • #3 21677080
    Priya dharshini
  • Start by measuring inductor inductance and resistance
    #4 21677081
    richard gabric
  • #5 21677082
    Priya dharshini
  • #6 21677083
    richard gabric
  • #7 21677084
    Priya dharshini
  • Inductor current rise and MOSFET SOA limits
    #8 21677085
    richard gabric
A pulsed DC power supply is being developed for magnetizing and demagnetizing an electromagnet using a 555 timer IC generating a 15V PWM signal with a 0-100% duty cycle and a 6.5 ms period. The supply includes a bridge rectifier converting 240V AC to 200V DC for the MOSFET and a 15V DC supply for the 555 timer. The main challenge is selecting a suitable MOSFET for switching the electromagnet without frequent device failure. Key issues discussed include the need for a proper MOSFET driver since the 555 timer output cannot adequately drive the MOSFET gate due to its capacitive load, and the importance of managing the inductor's back EMF to prevent MOSFET damage. The electromagnet has an inductance of approximately 5-6 Henry and a DC resistance of 285-300 ohms, values initially estimated by formula but recommended to be measured for accuracy. Proper understanding of the inductor's switching behavior, safe operating area of the MOSFET, and adequate gate drive voltage and timing are critical. Suggestions include using a buffer or dedicated MOSFET driver IC, implementing snubber circuits or diode clamping to handle back EMF, and ensuring the MOSFET is fully enhanced without excessive voltage. The discussion emphasizes revisiting fundamental inductor and MOSFET characteristics to prevent repeated component failures and achieve reliable switching performance.
