I am ready to build my own small control panel enclosure for this home project water heating tank that I am doing. This will be using 16AWG 120VAC. I will be using a circuit breaker for electrical protection, but not sure to use a single or double throw circuit breaker. I know 120VAC only use SPST breakers, Is it the same for my controls panel enclosure that will be using 120VAC power supply? I've dealt with three phase before, but not really a single phase. If I would use a sinlge pole breaker what will I do with the neutral wire? I know ground gets mounted to the frame and the black wire (hot) goes to the input side (power infeed) of the breaker. I know double throw breaker has two hot wires (240VAC). Do I use a double pole breaker for 120VAC and use both the black and white wires? White wire will be wired in one pole and the black wire in the other pole then ground to the frame? Am I totally wrong? I will be using terminal blocks that will contain jumpers, electomechanical contactor, heating element, and a temperature controller. All components will be 120VAC. If you have any questions for me please feel free to ask. Thank you very much.
Christopher Moya
Christopher Moya
