How To Tell Your Induction Motor Is Good Using Digital Megger?
438 6
  • Clarifying megger readings and 1000 V test voltage
    #1 21677980
    Christopher Moya
  • #2 21677981
    Richard Gabric
  • IR test thresholds and voltage guidance for induction motors
    #4 21677983
    Dishan Pangan
  • Megger voltage choice for dual-voltage motor insulation test
    #5 21677984
    Christopher Moya
  • 500V DC insulation resistance test recommended
    #6 21677985
    Dishan Pangan
  • #7 21677986
    Richard Gabric
The discussion addresses how to interpret insulation resistance (IR) test results of induction motors using a digital megger, specifically the UNI-T 5URG2 model. A reading of at least 1 gigohm (1000 MΩ) generally indicates good insulation, while values around 100 ohms or lower suggest poor insulation requiring maintenance. Testing involves placing the black probe on the motor casing (ground) and the red probe on each winding terminal to measure insulation resistance relative to ground. The megger applies a DC test voltage, commonly 500V or 1000V, to detect insulation integrity; DC voltage is used because it measures resistance rather than impedance. The choice of test voltage depends on the motor's rated voltage; for example, a motor wired for 208 VAC is typically tested at 500 VDC, closer to its operating voltage, while 1000 VDC is used for higher voltage motors. An "O.L" (open line) reading on the megger display indicates an open circuit, which may mean a winding is defective or disconnected. Reference standards and detailed procedures for motor insulation testing are available in industry papers and manuals, such as those linked from NETA and Instrumart, which provide guidelines on test voltages, interpretation of results, and safety precautions.
