Do the metal contacts of an electrical switch ever actually make contact with each other ?
543 19
Do mechanical switch contacts make direct metal-to-metal contact, or do they stay separated by a very thin film of air or oxidation?
Mechanical switch contacts do make microscopic metal-to-metal contact at many points; they do not normally stay separated by a uniform film of air. The contact faces are rough even under the microscope, and spring pressure squashes the microscopic peaks together so current flows only through those small contact points [#21678234] Any fluid films are pushed aside and brittle surface films are broken up, while trapped pockets of air or oxidation may remain in recesses rather than forming one continuous layer [#21678234][#21678232] Because the real contact area is so small, contact resistance is higher than that of a solid piece of the same metal and cross-section, and dirt or carbon gunk can make it much worse [#21678234][#21678216][#21678218] At high current, localized heating and arcing can melt the contact spots and even weld them together, which is why switches and relays have make/break/carry ratings and sometimes use hybrid shunting to protect the contacts [#21678218]
  • Switch contacts close through microscopic asperities, not an air film
    #1 21678215
    Noel Dillon
  • Microscopic metal contact and self-cleaning switch contacts
    #2 21678216
    Alan Winstanley
  • Switch contacts need metal-to-metal contact and cleaning
    #3 21678217
    David Ashton
  • Hybrid relay shunt prevents contact welding
    #4 21678218
    Elizabeth Simon
  • Contact spots and arcing in switch interfaces
    #5 21678219
    Alan Winstanley
  • Ring-shaped contact design aimed to reduce arcing
    #6 21678220
    Paul Bowden
  • Pressure acts on contact surfaces in equilibrium
    #7 21678221
    Noel Dillon
  • Switch contacts act like a low-resistance resistor
    #8 21678222
    Duane Benson
  • Metal contacts still make direct contact
    #9 21678223
    Noel Dillon
  • #10 21678224
    Noel Dillon
  • Bad capacitor caused switch contacts to weld shut
    #11 21678225
    Richard Thirsk
  • Atomic contact and electron repulsion in switch closure
    #13 21678227
    Max Maxfield
  • Switch contacts conduct without chemical bonding
    #14 21678228
    Duane Benson
  • Clarifying what occupies the gap between switch contacts
    #15 21678229
    Noel Dillon
  • Micro-scale contact effects in switch closures
    #16 21678230
    Duane Benson
  • Air gaps from surface roughness may prevent full contact
    #17 21678231
    Noel Dillon
  • Trapped air pockets and ionic surface attraction
    #18 21678232
    Duane Benson
  • #19 21678233
    Noel Dillon
  • Microscopic metal-to-metal contact points carry switch current
    #20 21678234
    Alan Dicey
Electrical switch contacts do not form a perfectly uniform metal-to-metal interface when closed; instead, conduction occurs at microscopic contact points where surface asperities physically touch. The contact surfaces are inherently rough and pitted at the microscopic level, causing only small areas of direct metallic contact. Any fluid films, oxidation layers, or contaminants such as carbon deposits are typically displaced or broken up by the mechanical force of the contacts closing, aided by self-cleaning wiping actions in some switch designs. A thin layer of air or oxidation may remain trapped in microscopic pockets between the contacts, but this does not prevent electrical conduction as electrons can tunnel or flow through these minimal gaps with low resistance. Contact resistance depends on factors including contact material alloys, gold plating, mechanical design, and cleanliness. High current switches require low resistance contacts to avoid localized heating and potential welding of contacts due to arcing. Some relay designs incorporate hybrid circuits with solid-state devices to reduce contact wear and prevent welding. The phenomenon of "cold welding" in vacuum conditions is noted, but under normal atmospheric conditions, a thin oxide or contamination layer usually prevents true atomic bonding between contacts. Overall, switch contacts rely on multiple microscopic metal-to-metal contact points to achieve reliable electrical connectivity.
TL;DR: Closed mechanical switches conduct through tiny metal asperities; dirty contacts can read “tens to thousands of ohms,” and “there has to be some metal to metal contact.” [Elektroda, David Ashton, post #21678217]
Why it matters: This FAQ helps technicians and hobbyists diagnose contact resistance, arcing, and cleaning methods so switches stay safe and reliable.
Do switch contacts ever truly touch metal-to-metal?
Yes. Conduction requires metallic contact at microscopic high points (asperities). Spring force squashes peaks together, creating many tiny metal‑to‑metal spots. Current flows through those micro-spots, not across the whole visible face. That’s why measured contact resistance exceeds a solid bar of the same metal. [Elektroda, Alan Dicey, post #21678234]
If they touch, why doesn’t the entire face conduct?
Surfaces are rough at micro‑scale. Only compressed asperities make contact, forming a sparse network of micro‑junctions. Fluids are pushed aside at these points and brittle films break, but large areas remain separated. The effective conducting area is far smaller than the apparent area. [Elektroda, Alan Dicey, post #21678234]
Is there always a thin air film between contacts?
Not a uniform film. Expect sporadic trapped pockets in surface valleys, plus oxides where exposed. Most air escapes as the contacts close; remaining pockets and films sit between non-contacting regions while metal asperities carry the current. [Elektroda, Duane Benson, post #21678232]
Why do dirty contacts measure high resistance?
Deposits and oxide films reduce real contact area and increase constriction resistance. One report showed closed contacts measuring tens to thousands of ohms until debris was removed. Cleaning or burnishing restores low-resistance conduction paths. [Elektroda, David Ashton, post #21678217]
How do I clean mechanical switch contacts safely?
  1. Disconnect power; lock out if needed.
  2. Spray non‑residue contact cleaner; let it flush debris away.
  3. Operate the switch several times; if needed, lightly burnish, then re-clean and dry. This displaces grime and restores metal contact spots. [Elektroda, David Ashton, post #21678217]
What is switch arcing and when is it worst?
Arcing is a plasma discharge that forms as contacts separate or approach. It erodes and heats surfaces, raising resistance. Manufacturers specify lower make/break ratings than carry ratings because arcs occur during transitions, not steady conduction. [Elektroda, Elizabeth Simon, post #21678218]
Can contacts weld together?
Yes. High current and arcing can melt asperities and fuse faces. One case welded so solidly it broke a connecting rivet when switched off. Prevent by respecting ratings and minimizing arcing. [Elektroda, Richard Thirsk, post #21678225]
What is a hybrid relay and why use one?
A hybrid relay pairs a mechanical contact with a solid‑state device that momentarily conducts during make/break. This shunts current while contacts move, slashing arc energy and extending life. “Does wonders for keeping the relay contacts from welding.” [Elektroda, Elizabeth Simon, post #21678218]
Are there self‑cleaning or wiping contacts?
Yes. Designers use springy alloys and wiping motions so contacts rub as they close, scraping films. Cleaners can fill micro‑roughness to reduce friction; contact force still drives through to metal contact. [Elektroda, Alan Winstanley, post #21678216]
Do switches cold‑weld in vacuum?
They can. Without oxide or contamination, opposing clean metals may share electrons and bond. In air, oxides and residues usually prevent true bonding. “In a pure vacuum…the two switch pieces might chemically/mechanically fuse.” [Elektroda, Duane Benson, post #21678222]
What is switch bounce?
Bounce is rapid, unintended opening/closing as contacts physically settle. It produces spurious pulses that logic circuits must debounce in hardware or software. See the referenced article for background and mitigation ideas. [Elektroda, Max Maxfield, post #21678226]
How big can power arcs get?
Very large. Utility gear uses gas‑filled circuit breakers to snuff arcs. One cited installation carried a 40,000 A rating, illustrating the scale of arc control in power systems. [Elektroda, Alan Winstanley, post #21678219]
Why doesn’t air pressure ‘glue’ two flat metals together?
Free molecules mainly escape; some become trapped in micro‑pockets. Without gravity, a plate can rest against a wall because impacts occur on exposed sides, not the interface. It dislodges with small force; it isn’t sealed by uniform film. [Elektroda, Duane Benson, post #21678232]
What actually ‘fills’ the space between atoms at the interface?
Electromagnetic forces dominate. Electrons in opposing materials repel, preventing interpenetration unless a bond forms. Trapped oxygen can oxidize or remain until displaced. Micro‑areas may fuse, oxidize, or just press together without bonding. [Elektroda, Duane Benson, post #21678230]
