Using Rotary Dials from Old British Telecom Phones with Arduino or Microcontrollers
300 7
  • Suggesting BT rotary dials for Arduino input
    #1 21678332
    Michelle OBrien
  • Pulse dialing details and Arduino decoding options
    #2 21678333
    David Ashton
  • CM8870 and Goertzel tone decoder examples
    #3 21678334
    Elizabeth Simon
  • #4 21678335
    Alan Winstanley
  • #5 21678336
    Aubrey Kagan
  • #6 21678337
    Rick Curl
  • #7 21678338
    David Ashton
  • #8 21678339
    David Ashton
The discussion centers on adapting rotary dials from old British Telecom (BT) phones for use with Arduino or other microcontrollers, inspired by Clive Maxfield's experiments with Western Electric #7 dials from US 500 series phones. British phone dials operate similarly to US models, using pulse dialing at approximately 10 pulses per second with a 66% break ratio. A 555 timer IC can be employed as a debouncer to generate clean pulses (e.g., 50 ms) from the dial contacts, which can then feed a 4017 decade counter or be processed directly by an Arduino for digit counting and further applications such as display or control functions. Early push-button BT phones may use pulse or tone dialing, but often contain matrix keypads driving internal ICs, complicating direct interfacing. Additionally, tone decoding methods such as using a CM8870 DTMF decoder or implementing a Goertzel algorithm on ARM processors are noted for related applications like amateur radio repeater control. The discussion also touches on the timing characteristics of pulse dialing and the potential for creative uses of pulse outputs, including driving mechanical devices like pinball machine scoreboard reels.
