Can the generator transmit? - VLF electromechanical transmitter
TechEkspert 8838 11
  • The piece focuses on the SAQ Grimeton electromechanical VLF transmitter, built around an Alexanderson alternator instead of tubes or transistors.
  • It shows why a 50 Hz generator cannot realistically serve as a radio transmitter and how the alternator's many pole pairs plus a gear-driven motor make higher-frequency operation possible.
  • Grimeton's transmitter runs at 17.2 kHz and reached 200 kW, feeding a 1.9 km antenna suspended on six 127 m steel masts.
  • The station still comes alive on Christmas Eve and Alexanderson's Day, but building an electromechanical receiver is presented as a hobby rather than a practical project.
  • Can the generator transmit? - VLF electromechanical transmitter
    From the electronics archive - Electromechanical VLF transmitter
    Can the generator transmit? The antenna can transmit by radiating RF energy delivered by the transmitter in the form of electromagnetic waves. The transmitter output signal can be modulated both in amplitude and frequency, which allows information to be transmitted via radio.
    Can a generator be a transmitter? An alternator can supply energy in the form of alternating current. It is easy to imagine a device delivering 50 Hz alternating current, a frequency much lower than the radio frequencies known today. It would be quite difficult to build an antenna system that works effectively at 50Hz (although ELF (Extreme Low Frequency) 3-30Hz and SLF (Super Low Frequency) 30-300Hz were used for communication with submarines, which required MW power).
    VLF (Very Low Frequency) range 3-30kHz
    You will not find the VLF band in a typical radio receiver, but in the past this band was used, for example, for telegraph communication. Today, there is still a transmitter that uses an electromechanical generator that uses an Alexanderson alternator. In Poland, there was the Transatlantic Radiotelegraphic Center in Warsaw, which also based its operation on a generator in the form of a high-frequency generator.
    SAQ Grimeton station near Varberg in Sweden - 17.2 kHz
    It is easy to calculate that a 50Hz 3000 rpm generator would have to rotate 344 times faster, which is rather difficult to achieve. Alexanderson's alternator had an appropriate design allowing for operation at a higher frequency and at a lower rotational speed (a large number of pole pairs). Alexanderson's generator was powered by an electric motor equipped with a gear increasing the speed of rotation. The transmitter in Grimeton reached a power of 200 kW, it used a 1.9 km long antenna suspended on six 127 m steel masts. The station was one of eighteen transmitters making up the global communication network.
    The "RF" energy was modulated with a magnetic amplifier controlled by a relay and a telegraph key. The transmitter is activated on Christmas Eve and usually on Alexanderson's Day (last Sunday in June or first Sunday in July, whichever is closer to July 2).
    You can get a QSL card for confirmation of transmission receipt.
    Interestingly - you can also build a receiver using an electromechanical oscillator:
    http://www.wireless.org.uk/mechrx.htm
    However, this is more of a hobby than a practical project.
    We are witnessing the rapid development of technology, it is already hard to believe that there used to be 200kW radio transmitters that did not use lamps or transistors in the transmitter's RF circuit.
    SAQ transmitter generator frequency tuning:
    The next additional broadcast on February 13, 2015. at 15:00 UTC
    http://alexander.n.se/evenemang/world-radio-day-transmission/
    Will you try to receive the SAQ transmission?
    Sources:
    http://alexander.n.se/in-english/
    http://www.grimetonradio.se/index.php/english
    http://www.vlf.it
    http://pl.wikipedia.org/wiki/Alternator_Alexandersona
    http://pl.wikipedia.org/wiki/Radiostacja_Varberg_w_Grimeton
    TechEkspert
    Editor
    TechEkspert wrote 7344 posts with rating 5713, helped 17 times. Been with us since 2014 year.
  • #2 14491546
    maxxim
    Rate: 68
    Do you know when the next broadcast in this band will be?
  • #4 15075516
    TechEkspert
    Editor
    Help: 17
    Rate: 5713
    Next week on Saturday, October 24, 2015. the "SAQ" station will broadcast at 10: 00UTC (12:00). The tuning will start at 09:30 UTC (11:30).
    http://alexander.n.se/in-english/saq-transmission/
    This time I will try to receive the broadcast content, is anyone also planning to receive?
    Would an electric or magnetic responsive antenna be better?
  • #5 15083988
    maxxim
    Rate: 68
    I'm going to pick up the broadcast. I am not sure if my set, i.e. active antenna and sound card + SAQrx, will work ;) . It's the first time I'm going so low !!
  • #6 15089103
    KaW
    Help: 170
    Rate: 306
    Why does the author use the words "w.cz". There is no RF energy here. There is an electromagnetic wave - it has a low frequency and high power.
    Requires large transmit antennas and large receive antennas.
  • #7 15092723
    TechEkspert
    Editor
    Help: 17
    Rate: 5713
    @maxxim maybe we will be able to exchange experiences with SAQ reception.
    A few hours before the broadcast, I had assembled two makeshift amplifiers.
    One based on the design DL1DBC using an operational amplifier and an antenna responding to an electric component. As the antenna, I prepared a printed circuit board and an ordinary telescopic antenna.
    The second amplifier was based on the design easyloop I used a cathode ray tube demagnetizing coil as the antenna.
    To set the position of the magnetic antenna, a tool that calculates the azimuth after entering the coordinates of two locations may be useful https://www.fcc.gov/encyclopedia/distance-and-azimuths-between-two-sets-coordinates ( SAQ transmitter coordinates ).
    Before SAQ transmissions, I connected the outputs of two amplifiers to both channels of the sound card. In an urban environment, unfortunately, I received mainly mains hum and a signal at the horizontal frequency of 15625Hz coming from working TV sets. I probably managed to hit the moment when one of the receivers was turned on.
    When the tuning and transmission started, I checked the signal with one of the SDR receivers providing audio from the browser: Wide-band WebSDR . Here is an example of a receiver located in Poland sp3pgx - WebSDR .
    Unfortunately, the built-in amplifiers did not allow for the SAQ signal reception, maybe the interference level was too high or I made a mistake.
    I am going to return to the topic of VLF frequency reception, especially since the receivers reacting to the electric component are quite simple in construction. The role of the antenna can be used as an aluminum box Audio Antenna by Pierluigi Poggi IW4BLG , B3CKS-ANTENNA
    You can find many ideas for making a VLF receiver:
    http://www.techlib.com/electronics/vlfwhistle.htm
    http://www.vlf.it/romero2/explorer-e202.html
    I found a description of a rather interesting receiver SP9HSQ - electrical component receiver perhaps its design will allow for better results.
    There are also materials describing the construction of the receiver with an "electric" and "magnetic" antenna:
    ELF-VLF multi-receiver
    Perhaps next time I will be able to better prepare for pickup.
    @KaW rightly, it is difficult to talk about RF at 17.2kHz, it is the output signal of the transmitter and the term "RF" may be a kind of abuse here, as for the receiving antennas they may or may not be large, e.g. MiniWhip or slightly higher http://sp9moa.moa.edu.pl/odebralismy-depesze-z-radiostation-grimeton-saq/.
  • #8 15093179
    KaW
    Help: 170
    Rate: 306
    The definitions and descriptions of WIKIPEDIA are the same. This lowers the value of this material.
    Element of basic knowledge of electromagnetic wave is omitted.
  • #9 17403321
    Marek LUB
    Rate: 35
    Hello W.cz. at the beginning of the 1920s is not the same as after 100 years.
    In this link there is much more about our transatlantic station http://www.nadkuje-babice.pl/
    This year I am going to receive signals from Sweden.
    Patent description of the first version
    https://patentimages.storage.googleapis.com/63/aa/cc/770731ff5bffee/US1008577.pdf
  • #10 17403920
    TechEkspert
    Editor
    Help: 17
    Rate: 5713
    When will you receive the transmission, what receiver and antenna?
    The description of the experiments with reception should be included in the articles.
  • #11 17404067
    Marek LUB
    Rate: 35
    I refreshed the topic in a survey, not counting on interest, thanks for the response. Have you provided some examples of receivers that you would recommend?
    There are two pickup dates, birthday and holiday, I don't have a plan. Heard about some games at around 40kHz. Apparently, this signal is always or was, knowledge from several years ago. I could train.
  • #12 17404227
    TechEkspert
    Editor
    Help: 17
    Rate: 5713
    In an open space, I would lean towards the receiver with the GP antenna reacting to the electrical component. In the housing, you can use an antenna that responds to a magnetic component.
The discussion revolves around the capabilities of a generator as a transmitter, specifically in the context of Very Low Frequency (VLF) electromechanical transmitters. Participants inquire about upcoming broadcasts in the VLF band, with references to specific transmission dates and the SAQ station. The conversation includes technical considerations regarding antenna types for reception, such as electric and magnetic responsive antennas, and the challenges of receiving low-frequency signals in urban environments. Users share their experiences and setups for receiving VLF signals, including the use of operational amplifiers and various antenna designs. The importance of large antennas for effective transmission and reception of low-frequency electromagnetic waves is emphasized.
TL;DR: SAQ Grimeton transmits 200 kW CW on 17.2 kHz twice a year; "200 kW without lamps or transistors" [Elektroda, TechEkspert, post #14414876] Use compact E-field or magnetic loops, notch 50 Hz hum, and aim 315° from central Poland.
Why it matters: VLF lets hobbyists copy intercontinental signals with parts you can build in a weekend.
• Frequency: 17.2 kHz continuous-wave Morse (A1A) [Elektroda, TechEkspert, post #14414876] • Carrier power: 200 kW at the alternator output [Elektroda, TechEkspert, post #14414876] • Antenna: 1.9 km flattop supported by six 127 m towers [Elektroda, TechEkspert, post #14414876] • Public broadcasts: Alexanderson Day (≈ 1 July) and Christmas Eve at 08:00–09:00 UTC [Elektroda, TechEkspert, post #14493257] • DIY active E-field probe parts ≈ US$15 [Mouser, 2023]
What exactly is the SAQ Grimeton transmitter?
SAQ is a 1924 Alexanderson alternator delivering 200 kW to a 17.2 kHz antenna wire 1.9 km long [Elektroda, TechEkspert, post #14414876] It sends hand-keyed Morse during short commemorative broadcasts.
How often does SAQ go on the air?
Official transmissions occur twice: Alexanderson Day (nearest Sunday to 2 July) and Christmas Eve morning. Extra tests are sometimes announced on alexander.n.se [Elektroda, TechEkspert, post #14493257]
Where can I find the next broadcast schedule?
Check alexander.n.se’s SAQ Transmission page. It lists confirmed UTC times and any additional dates [alexander.n.se].
Can a mechanical generator really be a radio transmitter?
Yes. An alternator with many pole pairs produces 17.2 kHz directly; the rotating armature replaces modern RF stages [Elektroda, TechEkspert, post #14414876] Electrical modulation is done with a magnetic amplifier.
Why do some users avoid calling 17 kHz "RF"?
RF often implies ≥30 kHz. At 17 kHz we are in VLF, bordering audio, so some engineers prefer “low-frequency electromagnetic wave” [Elektroda, KaW, post #15089103]
How large must an efficient 17 kHz antenna be?
A half-wave in free space equals 8.7 km. SAQ compromises with a 1.9 km flattop and 200 kW to overcome mismatch losses [Elektroda, TechEkspert, post #14414876]
Which receive antenna works best for VLF at home?
City listeners choose active E-field probes (Mini-Whip) or shielded magnetic loops to reject mains hum [Elektroda, TechEkspert, post #15092723] Open fields favor a simple grounded vertical GP of 2–3 m [DL1DBC design].
What simple receiver can I build?
Combine an op-amp high-impedance preamp with a sound card and SAQrx software. Parts cost under US$20 [TechLib VLF Whistle; Mouser, 2023].
How do I align a magnetic loop toward Grimeton?
  1. Look up your coordinates.
  2. Use the FCC azimuth tool; note bearing to 57°6′ N 12°27′ E.
  3. Rotate the loop for peak signal nulling local noise [Elektroda, TechEkspert, post #15092723]
Is copying SAQ legal worldwide?
Passive reception is legal in most countries because no transmission occurs. Always obey local spectrum-monitoring laws; some military regions restrict VLF scanners [ITU-RR 2019].
Are there other interesting VLF/ELF beacons?
Yes. Dual-use naval stations transmit RTTY near 18.1 kHz, and the Japanese JJY time signal runs 40 kHz at 50 kW [JJY, 2022].
What report can I send after reception?
Email your audio clip or SINPO report to info@alexander.n.se. They issue printed QSL cards confirming successful copy [alexander.n.se]."
