Bulk through-hole resistors with shorter leads or narrower band packaging sources?
204 8
  • Narrower resistor band packaging sources
    #1 21678477
    Andrew Gale
  • Resistor packaging varies by manufacturer and power rating
    #2 21678478
    Alan Winstanley
  • Accepting larger bags for bandoliered resistors
    #3 21678479
    Andrew Gale
  • #4 21678480
    EEWeb
  • #5 21678481
    Rick Curl
  • Cut resistor leads off bandolier tape before use
    #6 21678482
    David Ashton
  • #7 21678483
    Andrew Gale
  • Trimming resistor lead residue before breadboarding
    #8 21678484
    Andrew Gale
  • #9 21678485
    David Ashton
The discussion addresses the challenge of sourcing bulk through-hole resistors with shorter leads or narrower bandoliers for easier handling and packaging in small kits. Standard resistor bandoliers are typically about 6 cm wide, which complicates packing for educational soldering kits. Some suppliers, like Velleman, offer resistors on narrower bands (~4 cm wide), likely achieved by using a component sequencer machine that re-tapes components from multiple reels onto new, narrower tapes, trimming leads in the process. Resistors are commonly supplied in bandoliers (ammo packed) varying by manufacturer and resistor power rating, with smaller, lower-power resistors sometimes packaged on narrower tapes. Handling issues include adhesive residue from tape on resistor leads, which can affect breadboard contacts; trimming leads and cleaning with alcohol-based solvents is recommended. Alternative solutions include using larger resealable bags for storage and considering lower power rating resistors to obtain narrower packaging. Automated component handling equipment and homemade cutting tools are also mentioned as ways to manage resistor bandoliers.
