Affordable Surge Protector Recommendations for Home Use in Canada
330 6
  • #1 21678569
    Katina Batts
  • Varistors and TVSs for overvoltage protection
    #2 21678570
    David Ashton
  • #3 21678571
    Max Maxfield
  • #4 21678572
    David Ashton
  • #5 21678573
    Max Maxfield
  • #6 21678574
    David Ashton
  • #7 21678575
    Max Maxfield
The discussion addresses affordable surge protection devices suitable for home use in Canada. The primary recommendation is the use of varistors, also known as Voltage Dependent Resistors (VDRs), Metal Oxide Varistors (MOVs), or Transient Voltage Suppressors (TVSs), which are cost-effective, bi-directional components designed to protect AC circuits from overvoltage events such as lightning surges. These devices come in various sizes, voltage ratings, and current capacities, often appearing as small, brightly colored disks. For higher capacity protection, varistors can be mounted to grounding points like switchboard enclosures. For DC applications, devices such as the P6KE series, which function similarly to high-power Zener diodes, are suggested. The discussion highlights the importance of clarifying the specific protection requirements to provide more targeted advice.
