Choosing Between Lestar LF2001G-A and LF2005G-A Surge Protectors: Benefits and Considerations
21350 16
Should I buy a surge-protector power strip for a PC/TV setup, and which of the Lestar models is the better choice?
Yes, a good power strip makes sense, but mainly as a limited class-D surge protector and interference filter, not as full storm protection [#10853658][#10852425] If the building already has surge protection, the strip is an extra layer; if not, it may simply become the next part to fail, and there is no 100% protection against lightning or storms [#10852425] Lestar products are considered comparable to HSK Data, with Lestar generally having slightly better anti-interference filtering and HSK Data slightly better surge protection [#10854647] So the choice should depend on what you value more: filtering, surge protection, warranty, or insurance [#10854647] In practice, a solid strip is worth buying if you want a relatively cheap sacrificial layer that may cost around 100 PLN instead of risking much more expensive equipment [#10853658]
  • #1 10851829
  • #2 10851858
    stasiaktel
    If you want to protect something, buy a decent UPS, it is less likely that you will miss something ...
    As for the installation, not old and well-made are relative concepts ...
    Do you have a residual current device?
    As for the switches, I do not trust that the cable removed from the socket is always safer ...
    If a strip is rather something decent ... in the cheap ones there is an ordinary voltage stabilizer (capacitor and coil :P )
    can: http://www.apc.com/products/family/index.cfm?id=176
    I used to buy something similar for printers, but there were also major incidents at that time, I will not say how much it works.
    Moderated By Akrzy74:
    You have a good chance of winning an award in the annual competition "Nonsense of the year"
  • #3 10851945
  • #4 10851969
    stasiaktel
    my41s wrote:
    I had something like this - it was in this one that my switch burned out. How do these APCs relate to Lestar? Does it make no sense to buy a slat for a computer?
    Are they "smaller"? I would prefer to have even 3 sockets for TV.
    I didn't have Lestar and I didn't take it apart ... it's hard for me to say something.
    And in this APC it was surely a switch? I know they have a power cut-off system after a filter failure.
  • #5 10851979
  • #6 10852365
    r.10
    Rate: 21
    "Always" not enough sockets, the more so as sometimes the neighboring ones can be used (some larger power supply / transformer, or a control clock).
    my41s wrote:
    I am going to buy 2 power strips for 4-5 sockets (not more, if it had 3 - it would be good).
  • #7 10852409
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    stasiaktel wrote:
    Do you have a residual current system?
    Ooh, that's some news. I do not know this type of installation.
    Will I get a description of it? :D
  • #8 10852411
  • #9 10852425
    Miniax
    Help: 173
    Rate: 290
    The main question is whether the building (premises) has surge protectors.
    In the absence of such protectors, this strip will be another element to "evaporate".
    If there are protectors, I would think more about using an additional D-type protector for this type of equipment.
    Optionally, you can also invest in an on-line UPS.
    Because these types of strips provide dubious protection against overvoltage and are more suitable for filtering interference.
    It should be mentioned, however, that there is no 100% protection against the storm.
  • #10 10852443
  • #11 10852459
  • #13 10853400
    mar_cik
    Help: 101
    Rate: 156
    It makes sense, a good skirting board is worth buying. On the one hand, it is limited (usually to class D), but overvoltage protection, on the other, an external filter against connected devices suppresses interference from the installation (e.g. a neighbor's microwave oven), on the other hand, the same filter suppresses interference from operating devices that can get into the installation .
    Even if a power strip falls from overvoltage, it costs PLN 100, not thousands, which the equipment costs.
  • #15 10853705
    mar_cik
    Help: 101
    Rate: 156
    The Lestar and HSK Data products are quite comparable, although of course they are slightly different.
    Lestar generally has slightly better anti-interference filters, while HSK Data probably has slightly better surge protection systems.
    Guided by local patriotism, I support HSK Data :D .
    When choosing, you simply need to define what you want to emphasize, what should be a priority (it can also be a warranty period or insurance).
  • #17 10854775
The discussion revolves around the choice between Lestar LF2001G-A and LF2005G-A surge protectors for home use, particularly for protecting electronic devices during storms. The user seeks advice on whether investing in a surge protector is worthwhile given their well-maintained household wiring and existing grounding. Concerns are raised about the reliability of surge protectors, with some participants suggesting that a UPS (Uninterruptible Power Supply) might offer better protection. The conversation highlights the importance of surge protection, especially for sensitive equipment like PCs, TVs, and printers, and discusses the effectiveness of different brands and models. Recommendations include considering the specific needs for surge protection versus interference filtering, with Lestar and HSK Data being compared favorably in terms of features. Ultimately, the user decides to purchase two different surge protectors based on the insights shared.
