SC200 Amplifier Oscillation With PC Sound Card Input Destroys Q14 Output Transistor
306 20
Why does the amplifier go into MHz oscillation when a PC sound card is connected to the input with no audio signal?
The oscillation was caused by an open input-ground connection: the phono connector’s shield/tab was insulated, so plugging in the sound card connected only the signal lead and left the sound card ground floating, which let high-frequency noise drive the amplifier unstable [#21679353][#21679354] Once the input shield/ground is actually bonded to amplifier ground, the problem should disappear; the same behavior was observed with the other channel and even with commercial amplifiers if the shield is not connected [#21679354][#21679355]
  • PC sound card input triggers MHz oscillation
    #1 21679335
    huddslad huddslad
  • #2 21679336
    Alan Winstanley
  • #3 21679337
    huddslad huddslad
  • Diagnostic questions to isolate amplifier oscillation
    #4 21679338
    PeterTraneus Anderson
  • 1 MHz output oscillation stops when input is grounded
    #5 21679339
    huddslad huddslad
  • 100 nF output capacitor halves oscillation amplitude
    #6 21679340
    huddslad huddslad
  • RC snubber suggested across Q1 and Q2 collectors
    #7 21679341
    Richard Shadbolt
  • Request for suggestions to isolate amplifier oscillation
    #8 21679342
    huddslad huddslad
  • Check DC offset and input-side oscillation
    #9 21679343
  • Higher-gain BC546B/BC556B may be causing instability
    #10 21679344
    huddslad huddslad
  • Replace Q7/Q8 and add RC pole compensation
    #11 21679345
    Richard Shadbolt
  • #12 21679346
    huddslad huddslad
  • 1 MHz input oscillation with no load
    #13 21679347
    huddslad huddslad
  • BC546A/B gain difference does not affect SC200 stage
    #14 21679348
  • #15 21679349
  • #16 21679350
    huddslad huddslad
  • #17 21679351
    huddslad huddslad
  • #18 21679352
  • Diagnostic tests for magnetic coupling and damping resistors
    #19 21679353
  • Missing phono shield ground caused oscillation
    #20 21679354
    huddslad huddslad
  • #21 21679355
An SC200 amplifier channel exhibited high-frequency oscillation (~1 MHz) when connected to a PC sound card output, causing repeated destruction of output transistor Q14. The oscillation occurred without any input signal and was absent when the input was shorted or open. The amplifier was built on official SC200 PCBs, with BC546B and BC556B transistors replacing original A variants. Tests showed the oscillation amplitude reduced by adding a 100 nF capacitor in parallel at the output, but frequency remained unchanged. Suggestions included adding a 1 nF capacitor in series with a 100 Ω resistor across the collectors of the input differential pair (Q1 and Q2) to stabilize the circuit. The problem was eventually traced to an unconnected ground/shield on the input phono connector, causing high-frequency noise pickup and oscillation. Connecting the sound card ground to the amplifier ground eliminated the oscillation. The discussion also touched on transistor gain differences, component replacements (Q7, Q8, BAV21 diode, miller capacitor), and comparisons with other amplifier ICs like the TDA8954 and LM3886.
TL;DR: A 1 MHz input‑triggered oscillation destroyed SC200 Q14; fixing the insulated RCA ground stopped it. “An open input-ground connection would explain the oscillation.” [Elektroda, Anonymous, post #21679355]
Why it matters: If your SC200 howls the moment you plug in a PC sound card, check the input ground before swapping parts.
For: SC200 builders troubleshooting ultrasonic oscillation, blown outputs, or unstable behavior with source equipment.
How do I fix SC200 oscillation when I connect a PC sound card?
Verify the RCA shell actually bonds to amplifier ground. The reported fault was an insulated input jack that left the source ground floating. Once the shell was grounded, the 1 MHz oscillation disappeared and normal behavior returned. [Elektroda, Anonymous, post #21679354]
What’s the quickest test to confirm a missing input ground?
With the input otherwise open, clip a jumper between the PC sound card’s sleeve (ground) and the amp input shell. If the oscillation appears or changes when you move the jumper, the ground path is suspect and must be fixed. [Elektroda, Anonymous, post #21679353]
Can a bad load make things worse during debugging?
Yes. A temporary 5 Ω load pulled the positive rail into current limit and extinguished the rail LED. That indicates heavy current and risk to outputs. Use a proper dummy load and current‑limited supply during tests. [Elektroda, Anonymous, post #21679340]
Does using BC546B/BC556B instead of A‑grade devices cause instability?
No. The designer noted the stage gains and impedances make hFE differences negligible here. Quote: “The SC200 is an excellent design.” Keep B‑grade parts; fix grounding and compensation instead. [Elektroda, Anonymous, post #21679348]
What simple RC tweak can tame ultrasonic oscillation during diagnosis?
Try a 1 nF capacitor in series with 100 Ω across the collectors of Q1 and Q2. This compensation network has stopped HF oscillations in similar topologies. Remove after root cause is fixed if not needed. [Elektroda, Anonymous, post #21679341]
Will adding more output capacitance help?
Paralleling an extra 100 nF from output to ground halved the measured oscillation amplitude from ~0.4 Vpp to ~0.2 Vpp. It doesn’t fix a wiring fault, but it can stabilize testing. [Elektroda, Anonymous, post #21679340]
Should I install the input ferrite bead or an inductor?
Yes. If the bead is missing, fit it or try a small 2.2 µH inductor at the input. The goal is to attenuate RF ingress that can excite the loop. [Elektroda, Anonymous, post #21679343]
How do I check whether the oscillation is entering through the input ground path?
Scope both ends of the 10 Ω input‑to‑ground resistor with the sound card connected. If no RF appears across it, inspect the RCA shell isolation and ground wiring first. [Elektroda, Anonymous, post #21679343]
What is the ‘Miller capacitor’ in this context?
It’s the small capacitor across the VAS transistor that sets the dominant pole and overall loop stability. Replacing it alone did not cure the reported fault because the true issue was the open input ground. [Elektroda, Anonymous, post #21679342]
Could magnetic coupling from the output inductor L2 trigger oscillation?
It can contribute. The tall air‑core coil radiates field. Try moving steel or aluminum near it and observe changes, but treat this as secondary to correcting input grounding. [Elektroda, Anonymous, post #21679353]
What’s the safe three‑step process to diagnose SC200 oscillation?
  1. Power via current‑limited rails; verify DC offset near 0 mV at no load.
  2. Confirm RCA shell continuity to signal ground; fix any insulated jack issue.
  3. If needed, add 1 nF//100 Ω across Q1–Q2 collectors and an extra 100 nF at output for testing. [Elektroda, Anonymous, post #21679339]
Does the problem appear with input shorted or left open?
No. The faulty channel was stable with input shorted or open, and only oscillated when connected to the PC source with the ground floating. [Elektroda, Anonymous, post #21679339]
What statistic characterizes the failure mode?
The instability presented as roughly 1 MHz oscillation at the output. After adding 100 nF in parallel at the output, amplitude dropped by about 50%. [Elektroda, Anonymous, post #21679340]
Will replacing Q7/Q8 or small caps fix a ground fault?
No. Replacing Q7, Q8, the BAV21, and compensation caps did not stop the oscillation until the RCA ground issue was corrected. Prioritize wiring integrity. [Elektroda, Anonymous, post #21679347]
Do commercial amps react similarly if the source ground is left floating?
Yes. The user observed comparable misbehavior on CYRUS and QUAD units when the input shield was not grounded, confirming the importance of that connection. [Elektroda, Anonymous, post #21679354]
