Complete List of Components and Total Parts for Pic n’ Mix Project Series?
282 11
Is there a complete parts list and total component count for the Pic n’ Mix project series?
There is no fixed complete parts list or final component count, because the series is a worklab-style tutorial that may add or change parts as it develops [#21679419] The editor says the need for resourcefulness and possible updates is part of the format, so forthcoming articles may introduce new components based on practical experience [#21679419] For example, the fourth installment will add a graphics LCD display, with the author saying it is an eBay item and that the part number will be posted once he is happy it works [#21679422] He later identified the display he used as the TJCTM24024-SPI from eBay, and mentioned a larger 3.2-inch display might also work [#21679424]
  • Request for a complete parts list and series count
    #1 21679418
    Dennis Wright
  • PIC n mix is an exploratory worklab series
    #2 21679419
    Alan Winstanley
  • #3 21679420
    Mike Hibbett
  • Farnell delivery charges and PIC A2D concern
    #4 21679421
    Dennis Wright
  • Graphics LCD planned for fourth installment
    #5 21679422
    Mike Hibbett
  • DSP library must be linked in MPLABX
    #6 21679423
    Dennis Wright
  • TJCTM24024-SPI display confirmed, 3.2-inch untested
    #7 21679424
    Mike Hibbett
  • #8 21679425
    Mike Hibbett
  • Capacitor polarity questioned using measured bias voltages
    #9 21679426
    Dennis Wright
  • #10 21679427
    Mike Hibbett
  • Capacitor polarity should be reversed at 1.54V bias
    #11 21679428
    Dennis Wright
  • Ceramic 10 µF capacitors reduce leakage current
    #12 21679429
    Mike Hibbett
The Pic n’ Mix project series is presented as a worklab-based tutorial emphasizing exploration and adaptability rather than a fixed, structured construction project. Consequently, a definitive complete list of components for the entire series is not provided upfront, as parts and suggestions may evolve with practical experience. Delivery costs and sourcing components, such as from Farnell or eBay, are discussed, noting variations in shipping policies and supplier reliability following Maplin's closure. The series includes components like a graphics LCD display (TJCTM24024-SPI 2.4" and a potential 3.2" model) sourced from eBay. Technical details cover the use of a TLC555CP timer to generate a 10kHz trigger for the PIC’s A2D conversion and the necessity of linking the DSP library in MPLABX for FFT processing. A discussion on the correct orientation of a 10µF capacitor in the microphone preamplifier circuit references the Texas Instruments datasheet and op-amp biasing, with a recommendation to use low-leakage ceramic capacitors (e.g., AVX 08056C106KAT2A) for low-power applications. The series encourages resourcefulness and iterative learning, with forthcoming updates expected as the project progresses.
