SMD learning kit/kit - LED shell animation - NE555 and CD4017
p.kaczmarek2 2199 4
  • A self-assembly SMD learning kit builds a flowing-light LED display for practicing soldering SOP-8, SOP-16, and 0805 parts.
  • NE555 generates the clock pulses, and CD4017 counts them to light each LED in sequence; the potentiometer adjusts speed.
  • The kit costs around PLN25, includes a CR2032 battery, and ships with spare resistors and two extra LEDs.
  • It works without LED current-limiting resistors because of the low supply voltage, but success depends on clean soldering and checking for shorts.
  • Animation showing a light effect on a snail shell-shaped circuit board with blue LEDs. .
    Here I will present a self-assembly kit based on SMD, or surface mount, components. This simple kit allows you to practice soldering circuits in enclosures such as SOP-8, SOP-16 and 0805. Once assembled, you get a simple "flowing light" effect. The whole thing can be bought for around PLN25, although you can get it for up to five times less in a promotion.
    DIY LED assembly kit in seashell shape. .
    The kit presented here is for anyone who wants to practice soldering surface-mount components. There are various ways to solder it - you can even solder it in a suitable oven, but I solder it "on foot" with the - cheapest soldering iron, flux, binder, tweezers.
    Let's start with the contents of the kit. In addition to the board and the required parts, we also get an easy-to-understand English-language manual with pictures:
    SMD soldering kit with components and instructions. .
    Already at this stage I can see that we got spare resistors (two each instead of one) and with two spare LEDs. That's good, they're easy to lose.
    There's a CR2032 battery too, for power.
    We start soldering - according to the instructions. First I clean the PCB once, then apply flux, then a bit of lead binder.
    Close-up of a purple PCB for an SMD soldering kit. .
    Shell-shaped PCB with SMD mounting markings. .
    Purple PCB with space for SMD component mounting. .
    I then position the circuit. The dot on the layout marks the first pin. I match it to the dot on the PCB and grab its first pin.
    Close-up of a CD4017BM integrated circuit mounted on a purple PCB. .
    PCB board with a CD4017BM integrated circuit on a purple background. .
    PCB with a surface-mounted SMD chip on a purple background. .
    I grab the opposite leg (flux, binder) and then solder the others using the drag soldering method, passing the soldering tip over the legs. The binder melts and catches them, I remove the bridges this way, and if any short circuit remains anyway, I remove it with a braid.
    PCB with a soldered IC and braid for removing excess solder. .
    Close-up of a surface-mounted (SMD) integrated circuit soldered to a purple PCB. .
    Close-up of a PCB with a mounted SOP package chip. .
    The second circuit (NE555) analogously:
    Printed circuit board with SMD components ready for soldering. .
    Printed circuit board with SMD components and NE555 chip .
    I then soldered the diodes. The double line on the board corresponds to the 'coloured' end of the diode - the cathode. For convenience, I prepared several pads.
    Purple PCB with SMD components and spiral design. .
    Close-up of a PCB section with mounted SMD components, including an LED, on a purple and white patterned background. .
    Printed circuit board with SMD components and spiral pattern. .
    Close-up of a PCB with SMD components .
    DIY spiral-shaped kit with SMD components mounted in a holder. .
    Then the resistors - analogously. Here we have two values, not to be confused. 1kΩ, which is the designation 1001 and 100Ω which is the designation 101 or 1000.
    Purple PCB with designated areas for SMD components. .
    Close-up of a PCB with SMD components for soldering. .
    Close-up of a purple PCB with SMD components. .
    Now the switch. At it, be careful with the flux - so it doesn't get inside....
    Close-up of an SMD switch mounted on a purple PCB marked SW3. .
    As usual - I grabbed a leg, soldered the others. Potentiometer and battery slot left:
    Shell-shaped PCB with LEDs and integrated circuits.
    Ready, but before switching on, check for short circuits or cold soldering or bad soldering.
    The potentiometer, as you may have guessed, adjusts the speed of the light.
    The circuit itself is a classic 'flowing light' on an NE555 and CD4017. The NE555 generates a clock pulse and the CD4017 counts it and lights the corresponding diode.
    Electrical schematic of the NE555 and CD4017 circuit with resistors and LEDs
    The version in the topic omits the LED current limiting resistors, this works because of the low supply voltage.
    In summary , a simple and enjoyable toy to assemble. Perhaps there could be more of these elements, but would that be a plus? On the other hand, the impatient 'young able' may just want a kit that is easier to run, so more elements would be a disadvantage. Additionally, it can be pointed out here that the whole thing will work as long as the power supply, clock generator and counter are soldered well. Some of the diodes may be soldered wrong and it will still run.... and nothing teaches as well as correcting your own mistakes and looking for cold solders or short circuits, which are not difficult to find.
    I myself, with my visual impairment, had to play with soldering this a bit, but I have my ways:
    Phone as "microscope" and TQFP soldering - step by step video presentation .
    That's it from my side, and how would you guys learn SMD soldering? Is it better to solder ready-made kits, or maybe just find an old (for example) laptop on the electro-junk and solder and solder transistors to it until you get the hang of it? Although this is of course a whole other level, because in a laptop the board is massive and will take a lot of heat before you even solder a resistor....
    p.kaczmarek2 wrote 14762 posts with rating 12891, helped 659 times. Been with us since 2014 year.
  • Learning SMD soldering through LCD TV board repair
    #2 21510457
    maciej_333
    Help: 488
    Rate: 1607
    That's it from my side, and how would you learn SMD soldering?
    My first contact with SMD was in 2007, when I started working at Jabil Circuit Poland in Kwidzyn. It was a short episode in the summer holidays between technical school and university. I worked there repairing LCD TV boards that had failed some kind of functional test. Soldering such multilayered PCBs, which were also soldered without lead, caused me a lot of problems at first. In fact, it was my first experience with lead-free solders and, what is worse, with fluxes for them. The flux (a very thin flux) that was used at the time could suffocate you. After a while you got used to it. At the time, a very cool arrowhead with a hollow (minifal) was used. Something like this: Link .
  • #3 21511065
    TechEkspert
    Editor
    Help: 17
    Rate: 5689
    An aesthetically pleasing end result. It is reminiscent of the electronic badges that some people used to prepare and wear at electronic events.
  • #4 21511823
    Rate: 12891
    One could think of a similar 'badge/toy' with the Elektroda logo.
  • #5 21513835
    Andrzej_Tomaszewski
    Rate: 338
    Cool. I once made a badge for my daughter for a preschool playdate.
