Field Service Engineer vs Power Electronics Engineer: Which Career Path to Choose?
276 9
Which job should I choose for long-term career growth: field service engineer or power electronics engineer?
Choose the power electronics engineer role if you want to build deeper expertise and likely find the work more fulfilling in the long run; the field service engineer role will give you more day-to-day variety and some outside field work, but it uses your expertise less [#21679762] The power electronics offer also deserves clarification because WiFi and CAN bus are not obvious core power-electronics skills, so you should ask whether the role is genuinely broader and developmental or simply poorly defined [#21679763]
  • Comparing field service and design engineer roles
    #1 21679761
    Rakesh Rakes
  • #2 21679762
    David Ashton
  • Questioning WiFi and CAN bus requirements for power electronics role
    #3 21679763
    Aubrey Kagan
  • #4 21679764
    David Ashton
  • #5 21679765
    Elizabeth Simon
  • Clarifying whether one engineer handles power and communications
    #6 21679766
    Aubrey Kagan
  • #7 21679767
    Rakesh Rakes
  • #8 21679768
    Rakesh Rakes
  • #9 21679769
    Rakesh Rakes
  • #10 21679770
    Rakesh Rakes
The discussion compares two career paths: Field Service Engineer focused on commissioning, troubleshooting, repairing, and analyzing power electronic photovoltaic (PV) inverters, and Power Electronics Engineer involved in design and development, including schematics, component selection, layout, power supplies, and expertise in AC power control, WiFi, and CAN bus communications. The Power Electronics Engineer role is seen as offering deeper technical expertise and long-term fulfillment, while the Field Service Engineer role provides more varied daily tasks and fieldwork but may limit technical growth. The inclusion of WiFi and CAN bus in the Power Electronics Engineer role reflects the growing integration of communication protocols in power electronics, such as solar inverters with WiFi for data monitoring and automotive power electronics using CAN bus for control and communication. However, concerns were raised about the broad skill set required and potential job role ambiguity, suggesting candidates clarify job expectations with employers. Overall, the Power Electronics Engineer position is recommended for those seeking advanced design and development experience, while the Field Service Engineer role suits those preferring hands-on, diverse field activities.
