MORE SC200 amplifier unstable bias voltage across output transistor resistors troubleshooting
384 8
  • Unstable bias and drifting TP1–TP2 voltage on SC200
    #1 21680107
    huddslad huddslad
  • #2 21680108
    Alan Winstanley
  • #3 21680109
    huddslad huddslad
  • Faulty cermet bias pot caused unstable bias adjustment
    #4 21680110
    huddslad huddslad
  • #5 21680111
    Alan Winstanley
  • #6 21680112
    PeterTraneus Anderson
  • #7 21680113
    David Ashton
  • #8 21680114
    Ross Anderson
  • Thermal runaway caused by faulty bias thermistors
    #9 21680115
    huddslad huddslad
The discussion addresses instability and difficulty in accurately biasing the MORE SC200 power amplifier output transistors, specifically achieving a stable 4.4mV to 5mV voltage across the output transistor resistors. The main issue involves nonlinear and unstable behavior of the bias voltage when adjusting the trim potentiometer (VR1), with voltage readings fluctuating and dropping unexpectedly as the heatsink temperature changes. Troubleshooting revealed that faulty cermet trim pots caused the instability due to nonlinear resistance changes and erratic jumps in resistance values. Replacing the cheap Suntan cermet pots with higher quality, tested Bourns cermet potentiometers resulted in stable and linear bias adjustment. Additional advice includes testing thermistors (thermets) for linear resistance changes and ensuring they can be set accurately within a 1-ohm tolerance to prevent thermal runaway. Other constructors have reported similar issues and cautioned about potential damage to output transistors if biasing is not carefully managed. The discussion also suggests consulting DIY audio forums for further community support.
