Unfortunately, the image is too small to read. It seems that when images are copied into the forum, they get resized. In this case to 212x300 which is not enough resolution to see much. This is NOT your fault, just a highly annoying feature of this site...
OK Ephraim, sorry for the hassles. Try...- make a new post asking the same question and include your files there (they come out bigger)- post the PDF and try and post the DOC as well (but it may not let you do that)Thanks / DavidPS also if possible let us know how you calculated the gain, so we can see if you're doing that right.
The discussion centers on verifying the correctness of an amplifier gain calculation for a specific circuit configuration. The original calculation document was not initially provided, prompting requests to upload it in accessible formats such as PDF or image files. Attempts to share the circuit image were hindered by low resolution due to forum image resizing, making the details unreadable. Suggestions included reposting the question with higher resolution files and sharing the calculation method to facilitate accurate evaluation of the gain computation. AI summary based on the discussion. May contain errors.
