CP106D SCR Pinout Orientation—Is Top View Flat Side or Curved Side?
204 8
  • #1 21680739
    Graham Rounce
  • Flat side is the top view reference for pinout
    #2 21680740
    PeterTraneus Anderson
  • #3 21680741
    Graham Rounce
  • SCR test method using bulb, gate resistor, and holding current values
    #4 21680742
    David Ashton
  • #5 21680743
    Alan Winstanley
  • #6 21680744
    Graham Rounce
  • #7 21680745
    Elizabeth Simon
  • #8 21680746
    Elizabeth Simon
  • #9 21680747
    Donald Ferguson
The discussion addresses the ambiguity in the CP106D SCR datasheet regarding the orientation of the "top view" used to show pinouts. Consensus indicates that the top view corresponds to the flat side of the SCR package, which is narrower than the curved cylindrical side. The flat side typically has the writing and is considered the reference for pin identification. The datasheet's subtle line drawings represent the edges of the package sides, supporting this interpretation. Testing the SCR pinout can be done using a multimeter's diode-test function by checking the gate-to-cathode junction. Additional practical advice includes using a low-voltage supply or the multimeter diode test to trigger the SCR, employing a resistor as gate current limiter, and understanding SCR trigger and holding currents from the datasheet for proper testing. The discussion also notes the inconsistency in datasheet views (top vs. base) across different components, which can cause confusion during assembly.
