How to Design 1-3/4 Inch Square PCB Antennas for SM130 RFID Reader Chessboard Project
336 9
How can I design a 1-3/4 inch square PCB antenna for an SM130 RFID reader so a chessboard can scan 64 squares with one reader?
Use a PCB coil tuned for 13.56 MHz and treat the system as inductive coupling, not long-range RF; a multi-turn coil that fits inside the square is the suggested approach [#21681282][#21681283][#21681284] A reference design for a 55x55 mm PCB antenna is linked in the thread, along with a 13.56 MHz antenna design discussion that may help as a starting point [#21681279] For 64 squares, switch only one antenna to the reader at a time and scan the board square-by-square, because having many antennas nearby can cause interaction and detuning [#21681280][#21681281][#21681282] Be prepared for false reads from adjacent pieces or nearby metal, and adjust transmit power and/or use the reader’s SSI if available to only accept strong responses from the square being scanned [#21681281][#21681282][#21681283] The thread also suggests that a sufficiently directional multi-turn coil could help reduce adjacent-square interference, though modeling would be needed to know how much [#21681282][#21681284]
  • Need guidance on 1.75-inch PCB RFID antennas
    #1 21681277
    Haley Dumphy
  • #2 21681278
    Haley Dumphy
  • 55x55 mm PCB antenna and evaluation kit links
    #3 21681279
    David Ashton
  • #4 21681280
    Elizabeth Simon
  • Adjacent pieces may cause false RFID responses
    #5 21681281
    David Ashton
  • Multi-turn coil would improve antenna directionality
    #6 21681282
    Elizabeth Simon
  • Suggesting SSI filtering for square-specific RFID reads
    #7 21681283
    David Ashton
  • #8 21681284
    Elizabeth Simon
  • #9 21681285
    David Ashton
  • #10 21681286
    Haley Dumphy
The discussion focuses on designing 1-3/4 inch square PCB antennas for a chessboard project using a single SM130 RFID reader module with 64 antennas. Key challenges include antenna interaction due to proximity, requiring an antenna switching mechanism to select one antenna at a time and avoid interference. The system concept involves scanning the board square by square, but false responses may occur when adjacent squares have active tags, which could be mitigated by adjusting the reader's transmit power or using signal strength indication (SSI) to filter responses. The antennas operate primarily via inductive coupling at 13.56 MHz, suggesting the use of multi-turn coil PCB antennas within the limited size constraints. Directional antenna design is recommended to reduce interference and false reads, though modeling is necessary to determine effectiveness. References to external resources include a 55x55 mm PCB antenna and RFID evaluation kits from SonMicro. Additional requests for RFID design materials and articles were made. The discussion also notes the importance of considering metal presence near antennas as it affects tuning and performance.
