Most Common Energy Harvesting Mechanism Used in TPMS Sensors (RFID, Piezo, EM, etc.)
444 6
  • #1 21681482
    Yair Kava
  • #2 21681483
    sophia robin
  • TPMS sensors typically use coin cell batteries
    #3 21681484
    David Ashton
  • Magnet-coil energy harvesting suggested for TPMS sensors
    #4 21681485
    Rick Curl
  • Questioning why TPMS sensors need energy harvesting
    #5 21681486
    Yair Kava
  • #6 21681487
    David Ashton
  • Valve-stem TPMS with replaceable coin cells
    #7 21681488
    Rick Curl
The predominant energy source for Tire Pressure Monitoring Systems (TPMS) sensors is small coin cell batteries, typically CR1632 or similar watch-type cells, with battery life ranging from about 1 to 7 years depending on usage and design. Most commercial TPMS sensors are mounted on valve stems and rely on these batteries, which are often encapsulated with the sensor, requiring full sensor replacement upon battery depletion. Although energy harvesting methods such as electromagnetic induction (using a magnet and coil system activated by wheel rotation), piezoelectric, RFID, or thermoelectric transducers have been proposed, they are not widely implemented in current TPMS designs due to space constraints and power management challenges. Some experimental or niche systems use RF energy harvesting to power sensors without batteries, but these are not commonly available on the market. Supercapacitors have been suggested for energy storage in harvested energy systems but face size limitations. An example of a commercial system with replaceable coin cell batteries is the Nonda ZUS Tire Safety Monitoring System, which provides tire pressure and temperature data. Overall, battery-powered TPMS sensors remain the standard due to simplicity, cost, and reliability, despite the potential advantages of energy harvesting technologies.
