Energy-Efficient Voltage Measurement with ESP8266 and Li-Po 18605 Pack
czarny8322 2007 5
  • Switched voltage divider to cut standby drain
    #1 19108798
    czarny8322
    Rate: 14
    Welcome,
    I am building a wireless sensor based on the esp8266. The circuit will be powered by a li-po 18605 pack.
    The ADC in the esp measures voltages up to 1v - so I can use a voltage divider built with e.g. two resistors (e.g. 100R + 33R).
    The problem is that I would like the whole circuit to be energy efficient - so the ESP itself is woken up for a few seconds every 10 min - it measures and transmits the results. And such a voltage divider would "eat" energy all the time.
    Do you perhaps know of any better solutions that I could implement? Maybe some kind of transistor key?
    I would like the voltage to be measured only when I want it to be, and no extra energy would be lost.
  • #2 19108879
    andrzej55
    Level 37  
    Help: 306
    Rate: 375
    Use larger resistors e.g. total resistance of 10-100k. You will calculate the current that will flow from Ohm's law. In general, the larger the resistors, the more susceptible the measuring system will be to noise - this can be reduced by software filtering.
  • #3 19108981
  • Question about charging four parallel 18605 packs with TP4056
    #4 19110632
    czarny8322
    Rate: 14
    Welcome,
    The max voltage is 4.2V. I measured and it came out that such a divider takes ~50uA so with a pack capacity of ~3000mA this is a negligible value.
    However, I have a question about charging the 18605 batteries. I am currently connecting two batteries in parallel and charging them using the tp4056 module. I understand that with such a system each piece must be similar in parameters.
    The question is, can I charge 4 packs connected in parallel in this way?
    andrzej55
    Level 37  
    Help: 306
    Rate: 375
    czarny8322 wrote:
    Question, can I charge 4ry packs connected in parallel like this?
    Do you mean four batteries in parallel? You can combine with similar parameters. Of course, the charging time will increase proportionally because this tp4056 has a limited charging current of ~1A.
  • #6 19110721
    czarny8322
    Rate: 14
    yes, in parallel:) <br /> .
    many thanks for your reply.
