Can somebody please help me figure out the mechanics for my design project? (Need help with polarity
219 10
How can I wire a DPDT switch so it reverses a 6V DC motor without turning the motor on until a separate button is pressed?
Yes—wire the battery to the on/off button first, then route power through the DPDT switch to the motor so you can select forward or reverse while the motor is off [#21682058][#21682060] A DPDT switch is the right type for reversing a simple 6V DC motor because it swaps the polarity at the motor terminals [#21682060] For a basic motor-and-gearbox screwdriver, the suggested switches are likely suitable because the motor will probably draw only a couple of amps briefly on a 6V supply [#21682054][#21682056] If the screwdriver uses electronics or speed control, the circuit may need to be modified or rethought [#21682054] Use whichever switch best fits your build if its current rating is adequate [#21682056]
  • Use a separate on-off switch with the DPDT reverser
    #1 21682053
    Leo Freese
  • Switching polarity only works with a simple motor
    #2 21682054
    Chip Fryer
  • #3 21682055
    Leo Freese
  • #4 21682056
    Chip Fryer
  • #5 21682057
    Leo Freese
  • #6 21682058
    Chip Fryer
  • #7 21682059
    Leo Freese
  • DPDT switch wiring for motor polarity reversal
    #8 21682060
    David Ashton
  • #9 21682061
    Chip Fryer
  • How to upload a diagram file on the forum
    #10 21682062
    David Ashton
  • #11 21682063
    Angela Angie
The discussion addresses controlling the direction and power of a 6V DC motor in a battery-powered screwdriver redesign. The user plans to use a 3-position DPDT slide switch to reverse motor polarity for direction control but wants the motor to remain off when switching direction, using a separate on/off button to start and stop the motor. It is confirmed that for a simple motor with gearbox, this approach is feasible if the DPDT switch is rated for the motor's load current. Typical DPDT switches rated at 6A/125V or 16A/250V AC are likely suitable for a 6V DC motor drawing a few amps. The recommended wiring method is to place the on/off switch between the battery and the DPDT polarity switch, ensuring the motor does not run when changing direction. The DPDT switch reverses polarity by swapping connections, and the on/off button controls power flow. A center-off position on the DPDT switch is unnecessary since the on/off function is handled separately. Additional advice includes placing the on/off switch before any speed control circuitry to prevent battery drain when off. Diagram sharing tips for illustrating wiring were also discussed.
