King S22 Thermostat: How Is Apartment Heat Controlled Without Using the Thermostat?
516 18
How can an electric apartment heater with a King S22 line-voltage thermostat be controlled from outside the thermostat, and why do the heat settings seem to start working only above certain numbers?
Your heaters are probably not being controlled by an external device that changes the thermostat setting; what you are seeing is more likely an inaccurate, misadjusted, or damaged line-voltage mechanical thermostat, and the old King S22 is known to be imprecise [#21682195] [#21682196] [#21682200] These thermostats use a bimetal coil and have hysteresis, so two identical units can switch at noticeably different temperatures, and one may need internal calibration or replacement [#21682195] [#21682196] To prove the problem, put a thermometer next to the thermostat and compare the actual room temperature with the setpoint; if the measured temperature is several degrees off, the thermostat is out of adjustment or faulty [#21682193] [#21682195] [#21682200] If the building has outside control, it would usually be a load-shedding or power-disconnect scheme that shuts the heater off entirely, not one that changes the set temperature [#21682203] [#21682206] The safest fix is to have the landlord or an electrician service or replace the line-voltage thermostat; one reply recommends a modern KING ES120 or ES230 replacement depending on heater voltage [#21682193] [#21682191] [#21682198] [#21682207]
  • Possible external control of apartment thermostats
    #1 21682190
    Julie Nguyen
  • King ES120 or ES230 replacement recommendation
    #2 21682191
    Charles Lord
  • #3 21682192
    Julie Nguyen
  • Suggesting a thermometer test for thermostat calibration
    #4 21682193
    Elizabeth Simon
  • Thermostat calibration shifted by maintenance replacement
    #5 21682194
    Julie Nguyen
  • Thermostat coil misalignment or damage suspected
    #6 21682195
    Elizabeth Simon
  • Bimetal thermostat hysteresis and contact wiring issues
    #7 21682196
    David Ashton
  • #8 21682197
    Julie Nguyen
  • Line-voltage thermostat coil replacement not recommended
    #9 21682198
    Elizabeth Simon
  • External control likely overriding thermostat settings
    #10 21682199
    Julie Nguyen
  • Thermostat calibration may be off by 10 degrees
    #11 21682200
    Elizabeth Simon
  • Question about external control of electric heat system
    #12 21682201
    Julie Nguyen
  • #13 21682202
    Julie Nguyen
  • Outside power cutoff can disable heat entirely
    #14 21682203
    Elizabeth Simon
  • #15 21682204
    Julie Nguyen
  • #16 21682205
    Julie Nguyen
  • Load shedding controller may be cutting heat
    #17 21682206
    David Ashton
  • Need for temperature feedback and rewiring to make thermostat work
    #18 21682207
    David Ashton
  • Questioning whether the thermostat circuit can produce that heat behavior
    #19 21682208
    Julie Nguyen
The discussion centers on issues with old King S22 line-voltage thermostats controlling electric heating in an apartment. The thermostats, rated 125/250/277 VAC and 22 AMP single-pole, previously allowed continuous heating at low settings regardless of room temperature. After maintenance interventions, the heaters only activate above certain higher thermostat settings (e.g., 60 or 70), with no heat below these thresholds, deviating from prior behavior. The thermostats are simple bimetal coil types without programmable or adjustable set points. The problem persists with both King S22 and replacement Robert Shaw Climate 801 mechanical line voltage thermostats. Explanations include thermostat inaccuracy, possible misalignment or damage of the bimetal coil, and hysteresis effects causing different turn-on temperatures. It is unlikely that heating is controlled externally beyond power supply interruption or load shedding by the utility, which can disable heating entirely but not adjust set points remotely. Embedded microcontroller-based triac control circuits (e.g., PIC microcontroller burst firing designs) were discussed as potential advanced replacements but require rewiring and temperature feedback sensors to function as true thermostats. The consensus is that the thermostats themselves are the main control points, and external control of set points without internal thermostat adjustment is improbable. Testing with a thermometer near the thermostat is recommended to verify actual temperature versus thermostat setting. Replacement with more accurate electronic thermostats like King ES120 or ES230 is suggested for improved control.
TL;DR: Old line‑voltage thermostats can differ by about 10°F in turn‑on point, and, as one expert said, “that type of thermostat is generally not that accurate.” [Elektroda, Anonymous, post #21682200] Why it matters: This FAQ helps renters diagnose and document heat-control issues with King S22 and similar line‑voltage thermostats.
How is my apartment’s electric heat controlled if I don’t touch the thermostat?
With line‑voltage baseboard systems, the thermostat directly switches mains to the heater. If someone cuts power upstream, heat won’t run regardless of the dial. However, outside control cannot change your thermostat’s set point; it only enables or disables power. “They couldn’t control the temperature set point with just the wires.” [Elektroda, Anonymous, post #21682203]
Why do two identical thermostats turn heat on at different dial numbers?
Mechanical bimetal thermostats vary in accuracy. One may energize at a dial mark of 60°F while another needs 70°F. That’s normal manufacturing tolerance, not necessarily tampering. The poster summarized it plainly: “that type of thermostat is generally not that accurate.” [Elektroda, Anonymous, post #21682200]
What is hysteresis in a bimetal thermostat, and why do I hear a click?
Hysteresis is the intentional temperature gap between ON and OFF. You might set 70°F, hear a click when heating starts, and another when it stops near 75°F. The click is the switch actuating as the bimetal moves. This prevents rapid cycling but can feel imprecise. [Elektroda, Anonymous, post #21682196]
Can maintenance adjust my thermostat so the dial matches room temperature?
Many mechanical stats include an internal set‑point calibration. A tech can tweak it so the click aligns better with actual temperature, improving comfort and repeatability. If the room is 55°F and a 60°F setting doesn’t call for heat, you have solid grounds to request adjustment. [Elektroda, Anonymous, post #21682200]
How can I document that my thermostat is miscalibrated? (3‑step how‑to)
  1. Place a thermometer beside the thermostat and let the room stabilize.
  2. Set the dial just below where heat usually turns on; note the thermometer.
  3. If the reading is 5°F or more below the dial and no heat, photograph both and share with management. [Elektroda, Anonymous, post #21682193]
Is it safe to open or repair a line‑voltage thermostat myself?
Avoid servicing internal parts. Line‑voltage thermostats carry hazardous mains on their components, including the sensing coil in some designs. Replacement or calibration should be done by a qualified electrician to prevent shock, fire, or code violations. [Elektroda, Anonymous, post #21682198]
Could the maintenance team have wired something wrong?
If you had a double‑pole thermostat (e.g., D‑series), miswiring to the wrong contact could cause odd behavior. The King S22 is single‑pole, so that exact mix‑up doesn’t apply. Still, incorrect line/load connections can cause no‑heat or always‑on symptoms. [Elektroda, Anonymous, post #21682196]
Why did a new Robertshaw 801 behave like the old thermostat?
Your reports show the Robertshaw 801 also only heated above ~70–75. That suggests system calibration or wiring issues rather than one defective brand. Swapping back to the King with similar results supports this diagnosis. Documenting thresholds helps the technician target the fault. [Elektroda, Anonymous, post #21682199]
What’s a good replacement for an aging King S22?
A responder recommended KING ES120 (120 V) or ES230 (240 V) electronic thermostats. These models improve accuracy over old bimetal designs. Match the voltage to your heater rating plate. Professional installation ensures correct line/load connections and compliance. [Elektroda, Anonymous, post #21682191]
Can the utility or landlord throttle my heat remotely?
A load‑shedding controller can interrupt power to heaters during peak grid demand for minutes to hours. You’d see heaters disabled regardless of the dial. It won’t change your dial’s set point, only availability of power. Ask management if such a device is installed. [Elektroda, Anonymous, post #21682206]
Can a microcontroller and TRIAC board replace a mechanical thermostat?
Yes, but the example circuit cited lacked temperature feedback and required Line, Neutral, and Load wiring. It would need redesign or a larger MCU to add sensing and safety features. Buying a listed thermostat is simpler and safer for apartments. [Elektroda, Anonymous, post #21682207]
Why does the heat never shut off once it finally starts?
That behavior points to miscalibration, sticking contacts, or wiring that bypasses proper sensing. If lowering the dial stops heat but it won’t restart at that mark, photograph the dial and thermometer to prove the fault for service escalation. [Elektroda, Anonymous, post #21682208]
What is a line‑voltage thermostat?
It directly switches mains power to the heater, unlike low‑voltage HVAC thermostats that control a separate relay. Models like King S22 are rated 22 A at 125/250/277 VAC and mount on the room wall feeding baseboard heaters. [Elektroda, Anonymous, post #21682190]
What do “single‑pole” and “double‑pole” mean here?
Single‑pole breaks one conductor; double‑pole breaks both. Double‑pole offers full isolation when off. Your S22 is single‑pole; the similar D22 is double‑pole, which can change wiring options and failure modes if misconnected. [Elektroda, Anonymous, post #21682196]
I think the stove also overheats at low settings—related?
It’s likely unrelated. The thread focuses on heating controls. Electric range controls use different thermostats or infinite switches. Report the stove issue separately and request an appliance technician to inspect and document it. [Elektroda, Anonymous, post #21682190]
Can outside power control fake a different temperature set point?
No. Cutting or restoring power only enables or disables heating. It cannot shift the temperature at which your thermostat clicks. Only calibration, component faults, or thermostat replacement change that threshold. [Elektroda, Anonymous, post #21682203]
