Sony Surround Sound System Intermittent Speaker Issue Due to Inductor Dry Joint
351 8
  • Dry joint on output inductor caused intermittent speaker output
    #1 21682484
    Edward Chase
  • Wave soldering often leaves dry joints on heavy parts
    #2 21682485
    David Ashton
  • Resoldering large inductors and joints for rigidity
    #3 21682486
    Edward Chase
  • Edge solder joints prone to flex and heat failures
    #4 21682487
    Elizabeth Simon
  • #5 21682488
    Richard Gabric
  • #6 21682489
    David Ashton
  • #7 21682490
    Wagner Gravelle
  • #8 21682491
    Wagner Gravelle
  • #9 21682492
    dnenetos
A 20-year-old Sony surround sound system exhibited intermittent audio issues on one of its six loudspeakers, traced to a dry solder joint on a small ferrite inductor located between the amplifier and speaker connector. Initial suspicion of dry joints on speaker connectors was disproven after resoldering failed to resolve the problem. The faulty inductor joint was found on the same lead in two separate units, suggesting a manufacturing defect likely related to wave soldering near the PCB edge, where mechanical flexing during assembly can cause joint failure. The inductors measured approximately 1/2 inch diameter by 5/8 inch height, relatively small but heavier than typical resistors or transistors, contributing to joint stress. Later models addressed this by using dual inductors in a plastic case with four solder pads for improved mechanical stability. The system’s age and original leaded solder likely contributed to joint brittleness, while vibration from sound output and handling may have exacerbated the issue. Additional factors such as conformal coating contamination on leads were noted as potential causes of poor solder joints. Comprehensive resoldering of all large joints is recommended to prevent future intermittent faults.
