Best Methods for Organizing and Storing USB, Power, and Audio Cables Indoors
369 18
What is a good indoor system for storing and organizing USB, power, and audio cables so they are easy to find and retrieve?
Use wall-mounted slotted trunking for cables you access often, and bags or boxes for cables you rarely need [#21682949] [#21682963] The trunking works without the lid: the slots hold the cables, you can hang long leads doubled over, and you should choose slot sizes that keep the plugs from sliding through [#21682951] [#21682954] Make sure the trunking is fixed securely with enough screws, and use washers as well [#21682954] For less-used cables, store them in cheap zip-lock bags—quart or sandwich size for smaller leads, gallon size for larger ones—or in plastic boxes to keep them from tangling [#21682957] [#21682955] Larger cables can be coiled and secured with Velcro straps, twist ties, or tape, and very large coax can simply hang on a hook [#21682963]
  • Cable filing system for easy retrieval indoors
    #1 21682948
    Aubrey Kagan
  • Slotted trunking for wall-mounted cable storage
    #2 21682949
    David Ashton
  • #3 21682950
    Aubrey Kagan
  • #4 21682951
    David Ashton
  • #5 21682952
    Aubrey Kagan
  • #6 21682953
    David Ashton
  • More screws needed to support cable trunking
    #7 21682954
    David Ashton
  • #8 21682955
    Max Maxfield
  • Compact cable storage trades accessibility for discretion
    #9 21682956
    Aubrey Kagan
  • #10 21682957
    Elizabeth Simon
  • #11 21682958
    Aubrey Kagan
  • #12 21682959
    Elizabeth Simon
  • #13 21682960
    David Ashton
  • Leaning toward Tupperware and zip lock cable storage
    #14 21682961
    Aubrey Kagan
  • Trunking for frequent cables, containers for storage
    #15 21682962
    David Ashton
  • Cable storage using trunking, boxes, bags, and hooks
    #16 21682963
    Elizabeth Simon
  • Test lead racks still leave cable clutter
    #18 21682965
    Aubrey Kagan
  • Wire shelving repurposed as a test lead rack
    #19 21682966
    Daniel George
The discussion addresses effective indoor organization and storage methods for various cables including USB, power, and audio types, particularly in limited space environments. One practical solution involves using slotted trunking mounted horizontally on walls to hang cables by their plugs, preventing tangling and allowing easy access. Modifications such as omitting the trunking lid or using short sliding covers help secure cables without complicating retrieval. For less frequently used cables, stacking plastic storage boxes or oversized Tupperware containers is suggested, offering compact and portable storage. Additionally, zip lock bags of varying sizes provide a cost-effective way to separate and protect cables, reducing tangling. Velcro straps, twist ties, or tape are recommended for coiling larger cables that do not fit in bags or boxes. Specialized racks like Pomona Test Lead Racks and repurposed TightMesh Wire Shelving can also be used to organize frequently accessed cables, especially test leads, by hanging them on hooks or slots. The choice of method depends on cable usage frequency, available space, and portability needs, with a combination of trunking for daily use and containers or bags for storage favored. Proper mounting with sufficient screws and washers is emphasized for stability of wall-mounted solutions.
TL;DR: The average U.S. household now has 21 connected devices, and “41% of consumers dislike managing their devices.” Organize daily-use cables on wall slotted trunking; stash seldom-used ones in labeled boxes with zip bags. [Deloitte, 2023]
Why it matters: Clear storage cuts retrieval time, prevents damage, and keeps shared charging/work areas neat for families and small labs.
What’s the best way to store USB, power, and audio cables indoors?
Split by usage: mount frequently used cables on slotted trunking near the bench; file rarely used ones in labeled boxes with zip bags. This combo gives quick access while keeping clutter hidden. It’s the approach several posters converged on during the thread. [Elektroda, Anonymous, post #21682962]
How do I build a wall slotted-trunking rack for cables?
Pick duct with slot width smaller than your plug heads. Mount a horizontal length on the wall. Hang cables by their plugs or loop them through adjacent slots. “You really don’t need the lid.” [Elektroda, Anonymous, post #21682951]
How do I make sure the trunking doesn’t rip off the wall?
Anchor into studs or suitable anchors, use more screws than you think, and add washers to spread the load. Double long cables to reduce leverage. One user noted under-screwed trunking sagged; extra fixings cured it. [Elektroda, Anonymous, post #21682954]
Can I use the lid or partial covers on wiring duct?
You can skip the lid; the slots retain cables if you sized them right. If you want containment, slide short 6-inch lid segments where needed to keep loops tucked in. [Elektroda, Anonymous, post #21682952]
Are plastic boxes a bad idea for cable storage?
Boxes are space-efficient and discreet under desks. They trade speed for compactness: expect to “root around” unless you bag and label contents. Use them for spares, not daily leads. [Elektroda, Anonymous, post #21682955]
How do zip bags and straps reduce cable mess?
Bag small-to-medium cables by type/length in quart or gallon zip-locks. Coil large cables, then secure with Velcro straps or twist ties. This stops tangles and speeds selection from bins. [Elektroda, Anonymous, post #21682963]
What if I can’t drill into walls at home or work?
Mount racks to furniture or metal cabinets. Pomona-style lead racks can magnet-mount, though mixed BNC adapters challenge neat grouping. Tight-mesh shelving also screws to bookcase sides. [Elektroda, Anonymous, post #21682965]
Is wire shelving actually useful for test leads?
Yes. TightMesh or similar shelving with half‑inch centers and 0.38-inch slots holds hook leads and small probes well when mounted near your bench. [Elektroda, Anonymous, post #21682964]
Why bother organizing now—how many devices do I really have?
Households average 21 connected devices, down from a 2021 peak of 25. More devices mean more cables or adapters. Organization scales better than ad‑hoc drawers. [Deloitte, 2023]
What is Tuya?
Tuya (Tuya Smart) is a global AIoT platform that brands and developers use to build and manage smart devices and apps across categories. [Tuya Inc.]
What is Arduino Nano?
Arduino Nano is a compact, breadboard‑friendly microcontroller board (originally ATmega328P) offering Uno‑like I/O in a smaller form factor for embedded projects. [Arduino Nano]
What is OpenBeken?
OpenBeken is open‑source firmware that replaces Tuya/Beken and other modules, offering Tasmota‑like setup and Home Assistant/MQTT compatibility. [OpenBeken GitHub]
What is CAN bus?
CAN bus is a differential, multi‑master serial network (designed by Bosch) widely used in vehicles; classic CAN runs up to 1 Mbit/s. [CAN bus]
What did the thread starter finally choose?
They leaned toward a hybrid: Tupperware‑style boxes plus zip‑lock bags for shelf storage, while planning to inspect trunking at a surplus store. [Elektroda, Anonymous, post #21682961]
Any failure modes to watch for with wall racks?
Under‑fastened trunking can sag or detach when loaded. Use more screws, proper anchors, and washers to distribute force and prevent pull‑out. [Elektroda, Anonymous, post #21682954]
Quick 3‑step: how do I set up a grab‑and‑go cable wall?
  1. Mount slotted trunking level with ample screws and washers into studs.
  2. Sort cables by type/length; loop long ones to halve their drop.
  3. Hang by plugs; add short lid segments only where loops poke out. [Elektroda, Anonymous, post #21682951]
