I am working on a custom built energy management system that will be operated by a PLC given the scope of the project, I am looking for a run of the mill 7 day programmable thermostat that has duel outputs that can be interfaced via Wi-Fi. One of the outputs will be a dry contact that open and close as programmed for heat/cool and the 2nd output can be either and analog output that reflects the current temperature reading of the thermostat. It seems to be an elusive animal. I can use two separate components but it would look a bit weird on the wall. Thoughts?
Jerry Patterson
Jerry Patterson
