[Solved] Wanted thermostat to control a 6kW 400V heat buffer heater with WIFI control
raddam 984 4
  • #1 20643109
    raddam
    Hi. I am looking for a thermostat to control a 6kW 400V heat buffer heater, with temperature control and manual change via WIFI. The thermostat is to react to the room temperature and switch the heater on/off when the temperature drops below the set point. In addition, it would allow remote manual switching of the heating. Anything you recommend?
  • #3 20643480
    raddam
    I admire the skills but I'm all about the ready-made from the shop though. In the age of electrical plug-ins on WIFI for PLN100, the same thing with a temperature sensor, a sensible app and 400V support is enough.
    krzbor
    Help: 42
    Rate: 1072
    Buy a 230V circuit that suits you and add a 3f contactor to it. Such contactors can connect up to 25kW. Cheap contactors are about 60PLN, but their quality is questionable. If you want quality buy one like this: Link .
  • #5 20920449
    raddam
    Using a contactor solved the problem. Thanks!
