How to Find Current Draw of BU4811FVE Voltage Detector from Datasheet (1.8-3.6V)
420 10
How can I determine the current draw and power consumption of the BU4811FVE voltage detector at supply voltages from 1.8 V to 3.6 V using the datasheet?
Use the datasheet’s IDD1 and IDD2 tables on page 5 and the typical-current graph in Fig. 3 on page 6 to read the detector current at each supply voltage, then calculate power as P = V × I for each point [#21683011] The current depends on whether the device is in the on or off state, so check the correct IDD row for the condition you care about [#21683011] The table gives typical and maximum values, so use the maximums if you want worst-case design power and the typicals if you only want an estimate [#21683011] If you need precise values, the forum answer recommends measuring them, because the datasheet only gives a spread of values rather than an exact current for every unit [#21683011] For a low-power design, also account for the pull-up resistor on the open-drain output, since it affects total supply current when the output is low [#21683011]
  • How to read current draw from datasheet
    #1 21683010
    Qurat Ain
  • Use datasheet IDD tables and worst-case current values
    #2 21683011
    Richard Gabric
  • #3 21683012
    lumak lumak
  • #4 21683013
    Qurat Ain
  • #5 21683014
    Richard Gabric
  • Regulator power formula using 300 mA output current
    #6 21683015
    Qurat Ain
  • Clarifying output voltage and battery for switcher sizing
    #7 21683016
    Richard Gabric
  • Using 300 mA output to estimate regulator dissipation
    #8 21683017
    Qurat Ain
  • Estimate regulator loss from datasheet efficiency curves
    #9 21683018
    Richard Gabric
  • Request to verify mapped current curves for BU49xx detectors
    #10 21683019
    Qurat Ain
  • #11 21683020
    William Ali
The discussion focuses on determining the current draw of the BU4811FVE voltage detector across a voltage range of 1.8 to 3.6 V using its datasheet. Key guidance points to Fig. 3 on page 6 of the datasheet, which provides a graph of typical current values versus voltage, and a table on page 5 listing IDD1 and IDD2 currents (in µA) for different supply voltages and device states (on/off). Power consumption can be calculated by multiplying the current values by the corresponding voltage. The current distribution typically centers around typical values with some variation toward maximum values. It is clarified that the detector's current consumption is independent of microcontroller clock frequency changes, unlike microcontrollers themselves. Additional discussion covers power consumption modeling of switching regulators (e.g., TPS62740) using efficiency curves rather than discrete component modeling, emphasizing calculation of input and output power for best and worst-case scenarios. The user also references performance curves for related voltage detectors (BU4918, BU4922, BU4928, BU4933) to validate current consumption estimations. The overall approach involves extracting typical and maximum current values from datasheet tables and graphs, then applying these to power calculations for embedded system design and IoT applications.
