Connecting Grounding to Neutral in Electrical Setup with 2-Core Cable
Dj_Destroyer 30071 14
  • #1 6611967
    Dj_Destroyer
    Rate: 18
    Hello, I have a question, can you do as it is in the picture below? I am going to set up separately and I have a 2-core cable (phase and neutral) pulled to the house, there is no grounding, so I thought to do it as in the picture and here is my question, is it possible to do as it is done in the sockets that I make a bridge between neutral and ground ?
    Legend:
    blue color: terminal block for neutral conductors
    green: terminal block for earthing conductors
    green-yellow colors: ground wire
    To view the material on this forum you must be logged in.
  • #2 6612017
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    I am going to set up separately and I have a 2-core cable pulled to the house (phase and neutral)
    I wonder if you wrote this consciously ... Your statement suggests TT power grid (which I doubt).
    And this statement suggests that, however, the TNC, so you have L and PEN (or zero) power supply.
    Find out if I'm wrong - if I'm wrong.
  • #3 6612018
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    If you have a TNC network system (neutral-protective-PEN conductor), you can do so. You add differentials to it and you will become the owner of the TNC-S network system.
  • #4 6612513
    Dj_Destroyer
    Rate: 18
    I just don't know if I have L and PEN power supply. How can I check if I have it?
  • #5 6612536
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Dj_Destroyer-
    I just don't know if I have L and PEN power. How can I check if I have it?
    You will need to use the forum search engine :wink:
  • #6 6612617
    Dj_Destroyer
    Rate: 18
    Oh, and back to my question. Can it be done as shown in the picture?
  • #7 6612877
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    You have not specified what power network - without it, there should be no discussion, because we create a multi-topic thread ...
    If the TNC, then the PEN conductor is connected to the green strip, and your "bridge" (cross-section not smaller than the PEN) remains. According to the principle, protect first - power later.
  • #8 6613169
    Dj_Destroyer
    Rate: 18
    I was looking on the electrode but I did not find how to check if I have L and PEN power, how could you help me. I will be very grateful.
  • #9 6613217
    bartek0518
    Help: 45
    Rate: 49
    Call the utility company and ask.
  • #10 6615107
    Dj_Destroyer
    Rate: 18
    because I now have a bridge between the neutral and the protective one in the sockets in the kitchen and bathroom, so I think I have L and PEN power supply.
  • #11 6615397
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    The reset bridge suggests installation in a TNC network system (very likely). Look here-
  • #12 6615581
    Dj_Destroyer
    Rate: 18
    if I have a bridge in the socket between the protective pin and the neutral contact, I can do it as in the picture in the first post?
  • #13 6615684
    michal5102
    Rate: 9
    You can, it's only better if you do TNS right away.
  • #14 6615758
    Dj_Destroyer
    Rate: 18
    only where I will attach the protective wire, since in the staircase I do not have a 3-core cable, only 2-core.
  • #15 6615902
    golonka
    Rate: 17
    There is no need to guess !! call ZE and ask in what network system your installation is, no conversation makes sense.
The discussion revolves around the feasibility of connecting grounding to neutral in a residential electrical setup using a 2-core cable (phase and neutral) without a dedicated ground. Participants clarify that if the power supply is a TNC system (where neutral and protective earth are combined), creating a bridge between neutral and ground is permissible. However, it is emphasized that the user should verify their power network type (TNC or TNS) before proceeding. Suggestions include contacting the utility company for confirmation and ensuring that any modifications adhere to safety standards. The conversation highlights the importance of proper grounding practices in electrical installations.
