What signal types are safe to use with a return ground path for microcontroller switch modules?
270 6
  • Safe signaling over unused 3-way travelers
    #1 21683851
    John Starshak
  • Safe low-voltage signal over house wiring
    #2 21683852
    John Starshak
  • Safety concerns with using house ground as return path
    #3 21683853
    John Starshak
  • #4 21683854
    Elizabeth Simon
  • #5 21683855
    John Starshak
  • Is the switch board ground tied to box ground?
    #6 21683856
    John Starshak
  • #7 21683857
    Gracie Anderson
The discussion centers on the safe use of signal types over a single conductor (white wire) with the electrical ground as a return path in existing 3-way and 4-way switch wiring within a residential setting. The original poster aims to implement microcontroller-based switch modules that detect load voltage via an LED indicator, using the house wiring without introducing mains voltage on the signal conductor. The key technical inquiry is whether low voltage, low current signals—either AC or DC—can be safely transmitted over a 150-foot length of 14AWG wire using the electrical ground as the return path, while complying with electrical safety standards such as UL. Considerations include signal detectability along the entire wire length, minimal voltage drop, and adherence to safety regulations. The discussion references the X10 protocol as an example of signal injection on AC wiring but notes it is unsuitable for the project. Additional questions address whether the ground on commercial WiFi-enabled switches (e.g., WeMo) is directly connected to the electrical ground in the gang box, which impacts grounding and safety considerations. The overall focus is on identifying a safe, standards-compliant signaling method for microcontroller modules integrated into existing multi-way switch circuits using the house ground as a return path.
