How to Properly Connect AC Power Bank to Solar Panel Using Charge Controller?
441 14
How can I charge a 15V-input AC power bank from a solar panel without using the wrong kind of charge controller?
A standard 12V/24V solar charge controller is not the right match for this power bank; it is designed for lead-acid batteries and its output voltage is too low for a unit labeled “Input: DC 15V 2A” [#21684267][#21684264] The power bank appears to want about 15V on its solar/input port, and the supplied adapter measures 15.1V, so the simplest approach is to feed that input directly with a source that stays around 15V and can supply up to 2A [#21684268][#21684267] If you use the solar panel, make sure its output is suitable for that 15V input and does not exceed the power bank’s specified charging condition; the thread also warns that a “12V” panel can be around 19V open-circuit and that direct connection may be risky without proper limiting [#21684266][#21684271] One reply suggests the controller may be adjustable up to 15V, but it may still fail if it needs to “see” a battery-like 12V load to enter charging mode [#21684264] In short, do not try to power the controller through the power bank’s output; use a charger/controller meant for the power bank’s 15V Li-ion input, or test the panel directly only if the voltage/current are within the bank’s limits [#21684267][#21684271]
  • Power bank cannot power charge controller directly
    #1 21684258
    Gregory Carter
  • #2 21684259
    Alan Gallagher
  • #3 21684260
    Gregory Carter
  • #4 21684261
    Alan Gallagher
  • #5 21684262
    Gregory Carter
  • #6 21684263
    Elizabeth Simon
  • Float voltage may need adjustment to 15v for power bank
    #7 21684264
    Alan Gallagher
  • Questioning whether the power bank has a built-in controller
    #8 21684265
    Gregory Carter
  • #9 21684266
    Elizabeth Simon
  • Solar charge controller likely incompatible with Li-ion power bank
    #10 21684267
    PeterTraneus Anderson
  • #11 21684268
    Gregory Carter
  • #12 21684269
    Gregory Carter
  • #13 21684270
    johnathan miles
  • Bench-test 10–15V input tolerance and current draw
    #14 21684271
    Edward Chase
  • #15 21684272
    johnathan miles
The discussion addresses the challenge of charging an AC power bank with a solar panel via a solar charge controller. The power bank features separate input (15V DC, 2A) and output terminals, unlike traditional batteries where input and output are the same. The solar charge controller is designed for 12V lead-acid battery systems, providing a float voltage around 13.7V, which may be adjustable but likely insufficient for the power bank's 15V input requirement. The power bank's input port does not supply power to the controller, preventing the controller from operating correctly without a connected battery. The power bank may have an internal charge controller and is possibly intended for direct solar panel input, but the fluctuating voltage from typical 12V or 18V panels complicates this. Using the existing charge controller with the power bank is likely incompatible due to differing battery chemistries (Li-ion vs. lead-acid) and voltage requirements. Suggestions include testing direct solar panel connection to the power bank input, ensuring the panel can supply up to 2A at around 15V, or finding a charge controller compatible with Li-ion batteries and the power bank's voltage specifications. Caution is advised regarding voltage fluctuations and potential damage without proper regulation.
TL;DR: Your AC power bank expects 15V/2A input, and many "12V" solar controllers are for lead‑acid batteries only. “Do not charge except on the specified charging condition.” [Elektroda, Anonymous, post #21684267]
Why it matters: Mis-matching a 12V solar controller with a 15V Li‑ion power bank can prevent charging or cause damage.
This FAQ is for DIY solar users asking how to connect a solar panel, charge controller, and an AC power bank safely and effectively.
Can I charge an AC power bank through a typical 12V solar charge controller?
Usually no. Your controller targets 12V lead‑acid behavior, while the power bank needs a regulated 15V input. The controller expects a battery to manage charging and state‑of‑charge tests, which your bank’s input does not emulate. Use the bank’s 15V input with a suitable regulated source instead. [Elektroda, Anonymous, post #21684267]
What’s the correct wiring order for panels, controllers, and batteries?
Standard order is Panel → Solar Controller → 12V Battery → Loads. Do not place a Li‑ion power bank on the controller’s battery terminals unless the device is designed for that chemistry and voltage, which consumer AC power banks usually are not. [Elektroda, Anonymous, post #21684264]
Why won’t my controller power up from the power bank input or start charging?
Many controllers run from the battery and need it present. Some even short the panel when not charging. Without a 12V battery connected, the controller may not initialize or regulate, so the power bank sees nothing useful. “Some of the charge controllers I have, short‑circuit the solar panel when not charging.” [Elektroda, Anonymous, post #21684267]
Is it safe to connect a solar panel directly to the 15V input of the power bank?
Only if the panel voltage never exceeds the bank’s 15V spec. Unloaded panels can exceed 19–20V. If you try direct feed, add strong over‑voltage protection and test outdoors. A member advised bench‑testing first and warned about possible overheating or fire during trials. [Elektroda, Anonymous, post #21684271]
What voltage does a “12V” solar panel actually produce?
Expect about 21.8V open‑circuit, ~1.25A short‑circuit on a 20W panel, and around 17.6V at 1.14A at maximum power. These figures show why direct connection can over‑voltage a 15V input unless regulated or clamped. [Elektroda, Anonymous, post #21684267]
My wall charger reads ~15.1V. Does the power bank require a fixed 15V source?
Yes. The included adapter measured ~15.1V open‑circuit, indicating the bank expects a regulated 15V DC input. Replicate this with a suitable DC‑DC regulator when using solar, rather than a 12V battery controller output. [Elektroda, Anonymous, post #21684268]
Can I tweak my PWM controller to 15V to charge the power bank?
Your controller’s float is 13.7V and may be adjustable, but it might not reach or hold 15V. It may also require a 12V battery present to enter float mode. Therefore, even if adjustable, it remains unreliable for a 15V Li‑ion input. [Elektroda, Anonymous, post #21684264]
Do I need a small battery between the panel and the power bank?
You can add a 12V lead‑acid battery with the controller to stabilize panel voltage and absorb fluctuations. However, this adds losses and complexity. One workaround suggested loading the battery with a dummy load to keep panel voltage down, acknowledging inefficiency. [Elektroda, Anonymous, post #21684271]
How big should my solar panel be to feed a 15V/2A (≈30W) input?
A 20W panel typically delivers ~17.6V at ~1.14A, which is ~20W—below the 30W the bank can draw. Use a larger panel with headroom (for clouds, angle, heat). Consider ≥40W so the regulator can maintain 15V up to 2A in decent sun. [Elektroda, Anonymous, post #21684267]
How do I bench‑test if the power bank accepts various input voltages safely?
  1. Set a bench supply to 10–15V and current‑limit at ≤2A.
  2. Increase voltage slowly while monitoring input current and bank behavior.
  3. Stop if current spikes, the unit gets hot, or charging stops; test outdoors for safety. [Elektroda, Anonymous, post #21684271]
Why does the controller show no charge without a battery connected?
Controllers often measure and manage charge by interacting with a lead‑acid battery and may slightly discharge it for state checks. Without that battery, regulation and charging logic do not engage, so no charge flows. [Elektroda, Anonymous, post #21684267]
What if input voltage is below or above 15V on the power bank?
Below about 15V, charging may stall or cycle. Above 15V, you risk damage. The label warns, “Do not charge except on the specified charging condition.” Use regulation or clamping to remain within spec. [Elektroda, Anonymous, post #21684267]
