Noninverting op amp doesn’t work on highly resistive load
390 7
  • Output impedance and bias currents likely dominate here
    #1 21684882
    Michael Lamontagne
  • #2 21684883
    PeterTraneus Anderson
  • Current limit may be triggering on 5 MΩ load
    #3 21684884
    John David Heinzmann
  • 5 gΩ load is unrealistic for op amp output
    #4 21684885
    Richard Gabric
  • #5 21684886
    Michael Lamontagne
  • Oscillation suspected in PA443DF with 5 GΩ load
    #6 21684887
  • #7 21684888
  • High output resistance limits piezo drive current
    #8 21684889
    andreew kelvin
An Apex PA443DF operational amplifier configured as a noninverting amplifier with a gain of 22 was used to drive a low-frequency (approximately 1 Hz) sinusoidal signal at 100 V amplitude across extremely high resistive loads (up to 5000 MΩ). While the amplifier performed well with loads around 3 MΩ, the output amplitude dropped significantly to about 0.1 V with the 5000 MΩ load. The issue was identified as measurement error caused by the oscilloscope probe's finite input impedance (~1 MΩ), which formed a voltage divider with the high-value load, drastically reducing the observed output voltage. It was noted that the effective output resistance and measurement setup critically affect the observed signal. Suggestions included using a parallel 3 MΩ resistor to stabilize the load, verifying the actual circuit and measurement setup, and considering the amplifier’s internal current limiting or oscillation behavior. For low-frequency signals, increasing the compensation capacitor to reduce bandwidth and prevent oscillations was also recommended. The PA443DF is typically designed for driving piezoelectric loads with leakage currents in the microampere range, implying practical output load resistances are much lower than gigaohms. Proper measurement techniques and understanding of the amplifier’s output impedance and load conditions are essential for accurate signal observation.
