Precisely phase shifting very low frequency signal with RC filter
492 9
How can I generate 0°, 90°, 180°, and 270° versions of a 1–2 Hz analog signal using RC-based filters?
Use an active all-pass filter with an op amp; at 1–2 Hz the RC values will be large, so you need to pay attention to op-amp bias/offset current, offset voltage, and temperature drift if you want the phase to stay accurate [#21685006][#21685013] For the component values, there is no transfer-function advantage to larger or smaller parts, but keeping resistors reasonably low reduces noise and keeping capacitors smaller is usually practical, with values like your 8–16 kΩ range for a 10 µF capacitor being reasonable [#21685009] If you need better stability, film capacitors are preferred and are usually kept below about 1 µF, while fixed resistor pairs are better than a potentiometer because pots can drift and can fail open at the wiper [#21685010] A single 90° all-pass stage can provide the quadrature signal, and the 180° and 270° versions can then be obtained by inversion of the appropriate outputs [#21685006][#21685009] If you want to hit tight phase and DC-offset specs, simulate the circuit and use Monte Carlo analysis to check tolerance and drift effects before building it [#21685006][#21685010]
  • Need quadrature phase shifts at 1–2 Hz
    #1 21685005
    Michael Lamontagne
  • All-pass filter recommended for low-frequency phase shift
    #2 21685006
    Richard Gabric
  • Suggesting an audio phasing network or digital Hilbert filter
    #3 21685007
    PeterTraneus Anderson
  • Choosing RC values for a 1–2 Hz all-pass filter
    #4 21685008
    Michael Lamontagne
  • RC values are reasonable; adjust cutoff instead of gain
    #5 21685009
    John David Heinzmann
  • Use fixed resistors and matched film capacitors
    #6 21685010
    Richard Gabric
  • All-pass filter skews mixed sine-cosine waveform
    #7 21685011
    Michael Lamontagne
  • #8 21685012
    Michael Lamontagne
  • Temperature and op-amp specs drive RC phase accuracy
    #9 21685013
    Richard Gabric
  • Suggesting AC coupling and higher DAC output
    #10 21685014
The discussion addresses the challenge of precisely phase shifting a very low frequency (1-2 Hz) 0.3 V amplitude signal into four outputs with phase shifts of 0, π/2, π, and 3π/2 radians using RC filters. The recommended approach is to use active all-pass filters with operational amplifiers to achieve the desired phase shifts. Large RC values are necessary due to the low frequency, requiring careful selection of low bias and offset current op amps and components with low temperature coefficients to minimize drift and maintain phase accuracy. Practical considerations include choosing capacitor values (preferably film capacitors below 1 µF for stability and size), resistor values (balancing noise susceptibility and power dissipation), and the use of fixed precision resistors over potentiometers to improve stability. Simulation tools like LTSpice are suggested for design and Monte Carlo tolerance analysis. The phase shift varies with frequency, causing distortion when the input signal contains multiple frequency components. To obtain the four required phases, one can use a single π/2 phase shift all-pass filter, then invert signals to get π and 3π/2 shifts. Amplification to 30 V with less than 1 mV DC offset is feasible but requires careful component and op amp selection, considering temperature range, offset voltage, and input offset current. AC coupling is recommended to eliminate DC offset in the output stages. The output impedance of the signal source (0.2 Ω) is low, so loading effects are minimal but should be considered. Digital methods such as FIR all-pass filters approximating the Hilbert transform are mentioned as alternatives for precise phase control.
