GW Instek Signal Generator Shows 5Vpp, Oscilloscope Reads 10Vpp—Why the Difference?
399 6
  • Oscilloscope likely measuring open-circuit 10 Vpp output
    #1 21686039
    GreatTimes
  • #2 21686040
    David Ashton
  • Primary inductive reactance may be too low
    #3 21686041
    GreatTimes
  • Check generator accuracy with a 50 ohm resistive load
    #4 21686042
    David Ashton
  • Transformer impedance depends on load and leakage inductance
    #5 21686043
    David Ashton
  • Need for an LCR meter to measure inductance
    #6 21686044
    GreatTimes
  • Budget LCR meter recommendations from Newark
    #7 21686045
    David Ashton
A new GW Instek signal generator outputs 5 Vpp as indicated on the device, but the oscilloscope measures 10 Vpp when connected to discrete components including a transformer and resistor. The discrepancy is likely due to impedance mismatches between the signal generator's 50-ohm output and the complex, frequency-dependent load presented by the transformer primary. Inductive reactance (XL) at 1 kHz may be insufficient, causing unexpected voltage readings. Testing the signal generator output into a known 50-ohm resistive load is recommended to verify its accuracy. Transformer primary impedance varies with secondary loading and includes leakage inductance and reflected resistance, complicating measurements. The user lacks an LCR meter to measure inductance and is advised to acquire one for better diagnostics. Suggested LCR meters include the Peak LCR45 and Multicomp Pro MP780402, both suitable for hobbyist use and available from Newark.
