BTicino ART.344182 Receiver No Sound or Video with SCS 346830 Module and 343001 Doorbell
kamilkasza9 831 5
  • Receiver beeps but shows no display or audio
    #1 21784222
    kamilkasza9
    Hello, I have a BTicino system: a BTicino ART. 344182 receiver, a BTicino SCS 343001 doorbell, and a BTicino SCS doorbell module/call relay – model 346830, and a BTicino SCS 346000 power supply/controller (BUS 27 V). I ran 230 V to the power supply, a 2×1.5 mm² cable from the power supply to the module (PS), a 2×0.5 mm² cable from the module (TK BUS) to the doorbell, and a 2×0.5 mm² cable to the receiver (PI BUS). The doorbell has a 2×1.5 mm² cable to S- and S, and an electric strike to the gateway. The problem is that the signal to the gateway works, but there is no sound signal to the receiver or video. Could the 346830 doorbell module be faulty? I've checked the wires, and everything works. The addresses are correct. Thanks in advance.
    AI: Does the receiver (ART.344182) power on normally—do you see any lights, display, or menu when you try to use it?
    No, it just beeps when I try to press a button.
    AI: Has this system ever worked before, or is this a new installation/setup?
    Yes, this is an old installation; all connections checked.
  • #2 21785835
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Ref. 346830, is a video adapter, not a bell module.
    Check the voltage at each BUS location, i.e. at each component.
  • #3 21786094
    kamilkasza9
    There is 27v on each.
  • #4 21786110
    Ircys
    Help: 1342
    Rate: 2085
    To my eye the monitor has died since it doesn't even switch on from the button.
    Obviously you have tried switching the power off and on (after about 30s)?
  • #5 21786369
    kamilkasza9
    Yes, I also plugged in another monitor with the same effect.
  • #6 21786768
    Ircys
    Help: 1342
    Rate: 2085
    It is the individual components that need to be swapped. I would start with
    the power supply.
