The intercom does not work, the door cannot be opened with the intercom
lukasz19520 26217 9
Why does my apartment intercom have no sound in the handset and not open the door, and how can I fix it?
Check first whether the handset plug has slipped out, whether the black slider has turned the intercom off, and whether there is DC voltage on the line/input cables with a meter, including polarity [#16302278] [#16302539] [#16435701] If there is no reaction at all, the uniphone itself may be damaged or disconnected in the installation, possibly by the previous tenant or installer [#16302569] [#16303555] To separate a handset fault from an installation fault, have someone ring the apartment number and see whether the downstairs unit hears you when you answer the handset [#16302569] [#16303463]
  • #1 16301595
    lukasz19520
    No signal when someone wants to get to the apartment, you can not hear anything through the phone and you cannot open the intercom, please help. We moved and the intercom from the beginning does not work, I attach a photo
    • The intercom does not work, the door cannot be opened with the intercom IMG_0532.JPG (1.14 MB) You must be logged in to download this attachment.
  • #2 16302278
    Interesant
    Help: 204
    Rate: 249
    What is your apartment number 28 ??
    Ps. Check whether the plug from the earphone has slipped out?
  • #3 16302539
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Check the line voltage with the meter and check that the doorbell is not turned off (black slider).
    Regards
  • #4 16302569
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Another option is the damaged earpiece itself. The easiest way to check this is by sending someone to the door to dial the apartment number. Then, as he confirms that he did it, only then pick up the receiver and speak into the microphone. He should hear downstairs. Then you can also try to open the lock.
  • #5 16303463
    lukasz19520
    When the handset is lifted, the intercom rings really downstairs and does not respond to picking up the handset upstairs.
  • #6 16303555
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Well, this is the uniphone damaged or something in the installation. There is no reaction, so as if he was not there at all. The previous tenant may have been disconnected by the installer.
    If you can, check with a meter whether there is DC voltage in the line. If this is not the case, it will be solved.
  • #7 16427254
    domojoo
    Rate: 9
    Upload a photo of the external panel. Or write what the manufacturer is. If you have a DC meter, check the voltage on the line.
  • #8 16428806
    urquee
    domojoo wrote:
    Buy a new uniphone. I recommend you the following models: Cyfral Smart-d, Cyfral Mac-d, Wekta tk-7, Proel pc-512, Laskomex lm8, Urmet 1132/520
    I would consider proposing cameras from different manufacturers in one breath. As we have not seen the cassette (and it is also good to have a look at the electronics from which it is year) it is so rosy that everything is going wrong.
    In experience, you can only propose replacements from the same manufacturer.
  • #9 16429701
    suworow
    Help: 650
    Rate: 1278
    Right, it can't always be that easy. Amateurs of all digital installations that match all installations have already set up forums asking for help.
    Well, you can ask the author for a picture of the external panel. I strongly advise against searching for the headquarters ;)
  • #10 16435701
    cemtelec
    Rate: 11
    Check if there is voltage on the input cables and check the polarity.
The intercom system in the user's apartment is non-functional, with no audio signal when someone attempts to use it, and the door cannot be opened remotely. Suggestions for troubleshooting include checking the earphone plug, verifying line voltage with a meter, ensuring the doorbell is not turned off, and testing the earpiece by having someone at the door. It is also advised to check for DC voltage in the line and inspect the external panel for any visible issues. The possibility of damage to the uniphone or installation problems is noted, along with the recommendation to use components from the same manufacturer for replacements.
